Author Topic: Shure and Sennheiser frequency coordination  (Read 11271 times)
Jens Palm Bacher
    • Lydfabrikken
Re: Shure and Sennheiser frequency coordination
« Reply #10 on: February 08, 2017, 01:46:33 pm »
I got a equipment list.
He's got a setup of wireless mics and IEMs, not just IEMs as he originally told me.
IEMs
2x 4 channel racks with PSM1000 P10T and combiners.
2x 2 channel racks with PSM1000 P10T without combiners
All in J8E (554.125 – 625.850 MHz)
Mics:
10x 4 ch racks with EM 500 G3-G-EU and antenna distros
All in G (566 - 608 MHz)
A typical job where he mixes WL and IEM consists of 8-10 channels of IEM and 4 channels of WL.
His biggest concern is that WWB and SIFM reports differently regarding channel with and separation.
I have no experience with SIFM but I have used WWB6 successfully in the past for combining Shure and AKG.
Could it be that he should only use one program for his wireless planning instead of trying to combine two different ones?
Tell him to move the receive antennas minimum 10metres away from transmit antennas, this will most likely solve most of his problems with hits on the Sennheisers.
Ike Zimbel
    • Zimbel Audio Productions
« Reply #11 on: February 08, 2017, 09:14:16 pm »
IEMs
Mics:
Another thing he needs to keep in mind is that the IEM racks without combiners are going to produce a LOT more IM products than the ones on the combiner. I am (I hope) attaching a couple of screen shots showing the difference with and without a combiner. The red traces show the IM products that were produced when the 6 units were on individual whip antennas, the green trace shows the same units through a Sennheiser AC3000 combiner and a single antenna.
« Last Edit: February 08, 2017, 09:19:15 pm by Ike Zimbel »
~Ike Zimbel~
Wireless frequency coordination specialist.
Radio Active Designs
~416-720-0887~
Jordan Wolf
« Reply #12 on: February 08, 2017, 09:43:13 pm »
Ike,
What unit did you use to grab the scan data?
Jordan Wolf
Ike Zimbel
« Reply #13 on: February 08, 2017, 10:01:57 pm »
Ike,
Hi Jordan,
      1st pic is WWB, albeit a few versions ago (pics are from 2014) and the 2nd pic is the RF Command Center https://kaltmancreationsllc.com/pro-audio-wireless/invisible-waves-rf-analyzers/rf-command-center/
iz
~Ike Zimbel~
~416-720-0887~
Helge A Bentsen
  • Oslo, Norway.
« Reply #14 on: February 09, 2017, 05:11:21 am »
Thanks for the input :)
I'll have a chat with him and see if we can establish some best practices for doing this.
Christian Tepfer
    • Klanggestaltung Blog (German)
« Reply #15 on: February 09, 2017, 07:54:35 am »
I have a customer who has a number of Shure PSM1000 and Sennheiser EW500 G3 IEM units in these frequencies:
Sennheiser EW500 G3 - 566-608 MHz
Shure PSM 1000 - 554-626 MHz
He has tried coordinating them using WWB6 and WSM, but the results have been mixed.
It seems like the manufacturers programs does the best job on their own products.
Is there a reliable 3rd party software available that can coordinate both systems?
Or is there a way of making WWB6/WSM more reliable for coordinating both brands?
I have had good results with WWB and WinRadio and/or RFExplorer for scanning. I start with the least agile/selective units (the Sennheisers in that case) and build the coordination upon that results.
Christian Tepfer
christian at amanya dot de
Keith Broughton
  • Toronto
« Reply #16 on: February 09, 2017, 08:51:36 am »
As indicated, use one program only for coordination. There is no reason WWB should not work in this application.
+1 on the antenna location. Keep IEM TX away from receiver antennas. This is a HUGE issue I see all the time.
Kevin Maxwell
« Reply #17 on: February 09, 2017, 12:59:04 pm »
I use Shure’s Wireless Bench, I have for a while and I am very comfortable with it. I really like the latest update version 6.12 and I was surprised how much was changed and for the better. I thought with that much changed that it would have been version 7.
I usually have to coordinate Shure, Sennheiser and sometimes a small amount of wireless comms. I can get into a lot of detail but the basics are, due to lack of accuracy or band width restrictions with other methods, I get the best results using a WinRadio scanner. I use the WinRadio software with a plug in called Hit Counter and then I import the results into WWB 6.12 after manipulating the data in Excel. I have a partial macro in Excel and I need to sharpen my Macro writing skills and improve on that part of my procedures. But with the WinRadio I have found that the accuracy of the scans are right on. And WWB 6.12 has the different manufacturers systems defined in it so that is one reason I really like it. You can mix and match and get it all working together.
As other have said you need to coordinate in one system. And as I have indicated here it is best to also scan the environment and see what is out there to get the best coordination possible. And proper antenna techniques and placement.
There are two different venues I have worked in in one town and they are a few miles away from each other and I have tried to do a worse case coordination that would work in which ever place I am in but when I include the scan in the room I can never just use the same frequency set up for both rooms, it needs to be different for each room. Now I am being extremely picky, but because of that I have not had a problem with wireless that was the result of interference in a long time. I may try it again this year and see if I can come up with a coordination that works in both rooms. If I have the time and can scan both places ahead of time and merge those scans it might work.
