Sound Reinforcement - Forums for Live Sound Professionals - Your Displayed Name Must Be Your Real Full Name To Post In The Live Sound Forums > Rental Management Software Project
Feature List
<< < (4/7) > >>
Scott Holtzman:
--- Quote from: Ray Aberle on February 02, 2017, 02:16:23 PM ---
HOWEVER, a manner in which you could have a show file created, and it shows that x, y, and z are not available in your inventory, a quick and easy way to create a cross rental request and submit it to another company (either through a network interface, or simply input name and email address of your sales contact at the other company, and it automagically sends a "Do you have this available on this date?" request email. Then, the reply could automagically 'fill in the blanks' for you, indicating a positive response from the other company.
-Ray
--- End quote ---
Qwipped already has this.  They also have an API.  It's on my list of feature list.  From an inventory item have a "list on Qwipped" checkbox.  The great thing is you don't even have to list prices.
If that worked instead of logging on you could also seach qwipped from within the workspace
Andrew Broughton:
Some random thoughts, in no particular order, based on the limitations I've found with commercial rental inventory software...
1. Ability to choose "any" of a multiple item, or a specific one, when confirming a rental. e.g. You have 4 M7CL consoles, but there's a specific one you want to use on a particular job for whatever reason, you should be able to choose that one when booking. But, if the particular one doesn't matter, you can say so, and when the rig is prepped, whichever one you scan will get pulled from inventory. If a specific one was chosen when booked, it will prompt you to scan that one and not a different one. Choosing "Any" could be a default. Obviously some items will be serialized while others are not and are simply a quantity with no individual serial number. You cannot pick a "specific" item in this case.
2. Inventory should be able to be categorized into multiple "departments". e.g. a power cable could be used for sound, lighting or video. Having a single bin of power cables for any purpose may be one way your shop is set up, so you shouldn't have to be forced to have separate "audio power cables", "video power cables", if the 2 pieces are identical.
3. Warnings when building a quote if you try to quote an item that's not available or is pending on another job. Some systems allow you to quote whatever you want, and wait until you book it to check inventory. You may want to quote only items that you know you have available, or at least allow you to quote higher if you know that you'll be needing to subrent.
Cailen Waddell:
Rental Software Requirements
Im very train of thought - so if this is confusing forgive me
Tags - yay!
One important and probably obvious item of discussion is being non-destructive in edits.  For example, if a piece of equipment has it’s rate changed, any events that have already been quoted, should not update, but any future quotes should use the new rate.
Workflows should be somewhat customizable.  For example, I am a small shop/org.  I am simply NOT scanning shit in and out of the warehouse.  I want to book it, and see it on a pull sheet and move on with my life.  Some people may not want to do that.  It should be a choice.
Ability to suppress all finacials
Equipment - Data to have/track
   .csv import
   .csv export
   equipment categories will be tag based, so I’m not going to get into that.
   Serialized vs non-serialized.  Both should be options.
   Manufacturer, Model, Common Name, Purchase price, purchase date, replacement price, current value.  Qty
   Base Rate (There should be a base daily rate - users should be able to define the weekly rate as x times base, monthly, etc)
   I have two thoughts with regards to maintenance.  First is simply a free flowing field where entries can be made.  The second is child records with time/date stamps for each item
   Item history.  User based tracking of creation and change of items.
   A boolean value that indicates if equipment requires maintenance between every booking (a fogger for example, topping off fluid)
   other people have adequately described the need to package gear into groups and check in and out as a group.  There should also be the ability to book packages of non-perm. gear.  For example, “Small sound system”  That automatically pulls 2 of your 12 small speakers, mixer, cables, etc, in a non-serialized manner
Other customizable alert text on gear.  Can choose if alert pops a booking, or a pull, or scan, or whatever.  Some people use this with a text field to track lamp hours on projectors.
Contacts
This should be pretty straightforward, but there should be organizations and contact, and organization can have many contacts, but an event or rental can be attached to an org or a contact
Events/Bookings
Event name, pull date, pickup/delivery date, event start date, event end date, pickup/return date.  With some auto populate options.  A little scheduling module within an event could be nice too.  Nothing fancy but a simple date/time/description.  So I can say Day 1, 8am crew call, 10am client sound check, 12p lunch, 1p call, 2p doors, 2:30p show, 5:30p show ends, catered dinner, load out, or whatever.
Ability to upload files to events
Workflow - thoughts….
Equipment lists - I like a list.  even if we are tag based, there is going to need to be a sortable list.  I like to see serialized equipment listed individually, non-serialized with total quantities
An inventory reconciliation screen where you actually do inventory
When I book a show I like to put in dates, then have a pull list type entry of gear in, then a different screen where I can see invoices, and adjust, suppress individual lines, or all line items with just totals
Scott Holtzman:
--- Quote from: Cailen Waddell on February 02, 2017, 06:45:54 PM ---Rental Software Requirements
Tags - yay!
   .csv import
   .csv export
Contacts
Events/Bookings
--- End quote ---
Cailen,
Some really good stuff here.  I am not going to even begin to thing beyond the most basic fields for inventory.  The rest you are going to do yourself.  I already have a function that adds fields to a table in SQL and looks like this.  Just stick this on every inventory item:
For all you procedural code folks, this is all you have to do to make that data construct:
  <input type="text" id="custom_key_'+idx+'" name="sip_custom_key_'+idx+'" class="sip-custom" value="'+key+'" tabindex="'+tabindex+'"> =\
  <input type="text" id="custom_val_'+idx+'" name="sip_custom_val_'+idx+'" value="'+val+'" tabindex="'+tabindexp+'">\
Scott Holtzman:
Here is the same code in a newer prettier json type wrapper.
Navigation
[0] Message Index
[#] Next page
[*] Previous page
Go to full version
