Author Topic: Load monitoring margin of error  (Read 1187 times)
Adam Ellsworth
    • AirFader
« on: January 14, 2017, 07:37:58 PM »
I've been going through a bunch of JBL Vertec 4887s one at a time using the same Itech IT4000 amp for all. According to the continuous load monitoring, almost every speaker has been pretty much dead-on 8 Ohms both the Low Freq and Mid/High channels.
...except one which shows 12 ohms on the Low Freq side. The 87's have two 8" LF drivers, 16 ohms each. They both sound fine. How do I get 12 ohms? Is that within margin of error? Should I open it up and make sure terminals are tight? Or do I have a slightly bad driver?
Re: Load monitoring margin of error
« Reply #1 on: January 14, 2017, 08:09:14 PM »
I would guess 1 bad driver-or a bad connection.  The other driver might be on the way out or have a dirty connection.
The connections "might" be related.
If you have a bad driver you need to open it up-so I would do it anyway.
REMEMBER that the DC resistance will be around 12 ohms for a 16 ohm driver.
The amp is most likely looking at the impedance-NOT the resistance.
So keep that in mind when using an ohm meter to "look around".
Page created in 0.024 seconds with 18 queries.
