Author Topic: Luminaire info?  (Read 1019 times)
Sean Mormelo
Luminaire info?
« on: January 06, 2017, 11:06:12 pm »
Can someone who uses Luminaire give me the lowdown at this point? I plan to try it artnet midi controlled by my DAW synced set up. I'll program each tune. Seems very visual and I like that it's on IPad. I see I have the option of using it wired as well with an accessory.
I've checked out most of the other software and Luminaire for whatever reason looks easiest to me. DPro and DMXIS look simple too. As I said, this will be a programmed show but I like the ability of going live if needed.  I have a soundstage with full lights set up in my space so programming it visually won't be a problem.
How is the Midi? I have mostly Chauvet Pro moving fixtures R1 R2, and others. Is the profile library adequate?
Any real world experience and insight appreciated. I've read the older threads on it. Thanks.
Steve Garris
Re: Luminaire info?
« Reply #1 on: January 07, 2017, 05:47:58 pm »
You need to ping Debbie Dunkley on the Lounge forum. She runs Luminaire.
Re: Luminaire info?
Page created in 0.047 seconds with 23 queries.
