Author Topic: BTR 800 antenna combining  (Read 3965 times)
Pete Erskine
    • Best Audio
Re: BTR 800 antenna combining
« Reply #10 on: September 20, 2016, 12:04:53 am »
As further info and practical gig requirements come to light, I have a good solution. The 2 BTRs only need to service 2 separate channels of com.
There is a way to connect the 2 BTR base stations to allow integration of audio.
Turning off the TXs on one station then allows the other station to TX the 2 channels with the use of only 1 TX antenna. No combiner required.
Each station must still get an RX signal and that could be done with 1 antenna and a splitter.
There is a bi-directional log periodic available that might proove useful in this particular application. Could also use the Shure UA860SWB omni antenna.
less than 100' from the base I never use anything more than the whips which come with the base when I am using 1 base.   If you are not interfacing to a wired comm system be sure to terminate the loop between the bases.  You cannot connect them 4-wire, just connect with a single XLR A-A and set bases on RTS.  If you want to use the WTA connect the link jacks with a short Cat5.
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
Keith Broughton
  • Toronto
« Reply #11 on: September 20, 2016, 07:00:04 am »
The receivers are on a table and I do need more than 100' of range. The Shure omni should be fine to get the antennas up above the crowd.
Interfacing to a wired system that will provide termination.
May or may not need the WTA option but would like to have it available.
Thanks Pete.
Page created in 0.113 seconds with 22 queries.
