Author Topic: Clip light on Crown amps  (Read 12383 times)
Mike Diack
  • Auckland, New Zealand.
Re: Clip light on Crown amps
« Reply #10 on: September 18, 2016, 03:41:17 PM »
Re spurious clip lights on CTS2k & 3k, there are a few "usual suspects".
1: The 50 way ribbon cable between the input board and the main board - can be verified by wiggling the cable while running signal through the amp and observing what happend.
2: Loose faston connectors on the "tails" from the Lp/Ln chokes. Easily fixed by removing, squishing with pliers, and reconnecting.
3: There is a _|----------|_ shaped bracket under the output filter board tying the grounds together and contacting the case. The old version has a conductive squishy foam doing the case contact, the new version has sharks teeth. Fit the new version. While you're there, verify the tightness of the 8 screws that tie the main board to the output filter board.
4: It could be slightly blown up.
M
« Last Edit: September 18, 2016, 03:47:26 PM by Mike Diack »
Beatpower
« Reply #11 on: March 11, 2024, 06:23:27 AM »
Those are all true John, I have also seen the clip indicators light with damaged output sections.  I have seen this repeatedly, on different CTs on the same install.
CTs were quite awful when they first came out, lots of failures.  This was fixed in the 4 and 8 channel models and the later 2 channels.  Don't know that the stigma of the early problems ever wore off.
Lee
@Lee or anyone else, have you seen a CTS with the -20dB LED lit at one of the two channels, while there is nog signal?
It happens frequently, this channel also keeps failing; stops generating sound and after some seconds it comes up again.
What may be wrong?
  • Old enough to know better
  • Audio Plumber
« Reply #12 on: March 11, 2024, 08:32:00 AM »
What may be wrong?
Please go to your profile and change your displayed o your real full name as required by the posting rules.
admin
Page created in 0.039 seconds with 24 queries.
