Pages: [1] 2 3   Go Down
Author Topic: Temp power hook-up demonstration on This Old House  (Read 6847 times)
Jim Layton
« on: August 21, 2016, 12:39:08 pm »
I'm no electrician and don't play one on TV. Does this look ...real?
https://youtu.be/ldNfNj44FIQ
I also found this Philly IBEW video...which implies what everyone says here.  Don't play with live wires.
https://youtu.be/X6NHLZRAsgA
Between Allentown & Philadelphia
duane massey
Re: Temp power hook-up demonstration on This Old House
« Reply #1 on: August 21, 2016, 12:53:43 pm »
I've watched electricians do this many times. Won't do it myself.
Duane Massey
Houston, Texas
Cailen Waddell
« Reply #2 on: August 21, 2016, 12:56:32 pm »
I'm not an electrician either...  And I wonder about the ethics of skipping the meter in the example video from ToH.  That said, I have never seen power shut down before the meter in a residential situation.  Typically it is done hot afaik.
Jamin Lynch
  • Corpus Christi, TX.
« Reply #3 on: August 21, 2016, 01:01:48 pm »
I guess getting a small generator for power tools was out of the question.
And the home owners can't go without power for a while if it only takes about 5 hours to install the new box?
Seems like it would be safer than connecting live.
MAGA-Make Audio Great Again
Mike Pyle
  • Santa Rosa, CA
« Reply #4 on: August 21, 2016, 05:06:31 pm »
I noticed Mr. Electrician make a big deal out of the fact he was standing on a fiberglass ladder, but then passed a conductive coupling to the interviewer who was standing on an aluminum ladder.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #5 on: August 21, 2016, 05:29:43 pm »
Yes, but the coupling isn't energized and he wasn't touching a live connection.
Rob Spence
« Reply #6 on: August 21, 2016, 05:32:04 pm »
Replacing the service means connecting live no matter what. There is no individual disconnect at the poco and they are not going to drop the whole street just to change a service.
Rob Spence
« Reply #7 on: August 21, 2016, 05:35:37 pm »
If I did services all the time I think I would have a meter box with CS in and out so I could transfer the meter and avoid the ethics issue.
On the other hand we are likely talking about a buck or two of usage for the day (being actually 1/3rd of a full day.
Brian Jojade
« Reply #8 on: August 21, 2016, 05:37:18 pm »
I don't know where to start on that whole setup. WOW!!!  Nothing about that seems right. Bypassing the meter completely?  Yikes.
The argument that power is needed in the house is a bit strange too, as their power tap is just external for some power tools.  The house is still without power unless they run a bunch of extension cords.
Either the power was off at the pole, or the load was already disconnected at the breaker panel, as you would probably have seen a spark when cutting a live wire under load.  I especially found it exciting that he started by cutting the neutral wire to 'get it out of the way'  LOL.  Electricians.....
Brian Jojade
Rob Spence
« Reply #9 on: August 21, 2016, 05:43:52 pm »
I expect they threw the main switch in the basement first.
I also expect they ran some extension cords for the freezer and fridge.
What bothered me is there is no ground mentioned.
Pages: [1] 2 3   Go Up
Page created in 0.044 seconds with 23 queries.
