Author Topic: 240 volt to 2 x 120 volt 15/20amp connectors  (Read 4789 times)
Bob Faulkner
  • Raleigh, NC
« on: August 20, 2016, 06:08:55 pm »
Anyone using 240 volt to 120 volt electrical pigtails... similar to the attachment?
The attached image is from what Home Depot sells.  I'm looking for something like this, but more "appropriate" than what Home Depot sells (i.e. SOOW cord).
I'm looking to pick up a few and would be interested in what others are using (or have used).
Thanks.
Jerome Malsack
Re: 240 volt to 2 x 120 volt 15/20amp connectors
« Reply #1 on: August 20, 2016, 06:34:04 pm »
Better to ask in the power and grounding side of the forum ?
Cailen Waddell
« Reply #2 on: August 20, 2016, 06:49:35 pm »
There is no safe way to do it without a breaker or gfci on each outlet IMHO.
Bob Faulkner
  • Raleigh, NC
« Reply #3 on: August 20, 2016, 07:03:19 pm »
oops, yes this should have been posted in the electrical section.
Jerome Malsack
« Reply #4 on: August 20, 2016, 07:24:35 pm »
Ok are you connecting this to a generator for the power source ?
The cord you show is typical of the contractor grade generators and has the breaker at the generator for each side of the pig tail.
It would be better to use a power distro that is made by the electricians and meets the codes for the industry.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #5 on: August 20, 2016, 07:25:32 pm »
Thanks.
Adapters like that are only acceptable if the input is a L14-20 connector. Any other combination will either not have the correct wires or not have the necessary over-current protection.  Look into spider boxes for a low-cost distro that can be adapted to more scenarios safely.
« Last Edit: August 20, 2016, 08:47:12 pm by TJ (Tom) Cornish »
Bob Faulkner
  • Raleigh, NC
« Reply #6 on: August 20, 2016, 08:11:21 pm »
These would not be used on generators.
There's been a couple of sites where I've provided sound where they had a few 240 volt "feeders" (female ends) directly attached to their load centers.  Basically, you could "tie-in" to their load center using their provided feeds.
Adapters like that are only acceptable if the input is a L14-20 connector. Any other combination will either not have the correct wires or not have the necessary over-current protection.  Look into spider boxes for a low-cost district that can be adapted to more scenarios safely.
We use spider boxes when there's generators involved.
The tie-in "dongles" hanging out of these load centers look like they are made pretty good (SOOW wire, Hubble connectors, all in great shape).  Using their provided "tie-ins" would give me access to more circuits.  And yes, I would need to double check what type of connectors are in use (i.e. L14-20, etc...)
Thanks for the replies.
Ray Aberle
    • Kelcema Audio
« Reply #7 on: August 20, 2016, 08:38:23 pm »
"Directly Attached" through a breaker, or straight to lugs?
-Ray
Kelcema Audio
Bob Faulkner
  • Raleigh, NC
« Reply #8 on: August 20, 2016, 08:50:51 pm »
-Ray
Through a double-pole breaker.
These load centers, with the "feeders", are in commercial buildings.
Stephen Swaffer
« Reply #9 on: August 21, 2016, 03:20:18 pm »
Regardless of shore or generator power, the most important thing is not the actual connectors involved, but rather the Over Current Protective Device protecting the circuit.  Since you will be using either 15 or 20 amp cords/plugs, the OPCD needs to be rated 20 amps or less.
Steve Swaffer
Page created in 0.051 seconds with 24 queries.
