Pages: 1 [2] 3 4   Go Down
Author Topic: [SOLVED] NEED HELP - Desperately needing help to split frequencies (01V96i)  (Read 8073 times)
Don T. Williams
    • Q Systems Music & Sound
These are clever work arounds, but I'm just wondering, is it possible the PA system is active with all the amps and cross-over filters in the cabinets?  I don't understand how anyone could have ever used the system before without cross-overs!
As a system owner, I would never, never, never send it out without having a cross-over/ system processor as part of the system.  I learned 30 years ago to have fixed cross-over points (not user adjustable) or a "locked" processor for anything I rented out.  If anybody can change things, they would!  I had a "national act" FOH engineer change the LF to Lo-Mid x-over point from 300 hz to 80 hz and blow 48  6.5" drivers because he didn't know what he was doing (or didn't care . . . or worse did it intentionally)!  It happened in the last 30 seconds of the encore and really didn't effect the show.  We were lucky???
Chris Hindle
No, he blew your shit up on purpose.
Luck had nothing to do with it.
Chris.
TJ (Tom) Cornish
  • St. Paul, MN
Chris.
And this is why the world has largely moved to a black box processing model.
Douglas R. Allen
Those are some nice graphs, Douglas. I would appreciate a lot if you could post some extra pictures for me to make some sense of it and maybe manage to make this sound a little decent.  :D
This is a wedding weekend for me. Practice tonight. Dinner Friday. Saturday the show. If you don't need the crossover information until next Friday I'll post what I have Sunday morning. Bunch of pictures an approaches.
Douglas R. Allen
Douglas R. Allen
I still run into bands that use EQ to "try" to crossover a system. Think SP2's and a pair of 18 inch subs. Left channel 100hz and below pulled out for tops. Right channel 100hz and above pulled out for subs. Then I look and the amps have a basic crossover in them.......
Douglas R. Allen
Don T. Williams
Chris, I think you are right.  +1 for T.J.  I don't think there were any "black box" processors available at that time.  Meyer came up with the first I saw soon after that.
I'm still curious about the "system" being rented in this thread.  Is it really a "system" of just a collection of boxes and amps.  If so, that's pretty scary IMO !  My advise is to look for a real system to rent!
Fernando Lucchesi
Douglas R. Allen
Actually, I meant this Friday (tomorrow), but don't, worry, Douglas, I can make it work with the information you provided. Thanks a lot!
Fernando Lucchesi
Yeah, this is a really scary PA system, and to think the band has a pretty decent backline, JCM, Hartke, Pearl... They rented the PA from a guy downtown, he's a lighting technicians who ended up buying some cabinets so he could sell the whole smash instead of just renting lighting and L.E.D. dancing floors. The band contacted me after they heard this guy's PA without any x-over or EQ straight from a WATTSOM console (VERY LOW-END National Console).
These is what I'm dealing with...
They though about renting my system instead, but unfortunately, I only own 4 "18 subwoofers and 6 2x6" lines (HIGH-END fortunately).
The problem is, I didn't get to look at the real situation until yesterday, so not enough time to get everything I need for this to sound half-decent
  • Old enough to know better
  • Audio Plumber
At what time? Before founding Meyer Sound Labs John Meyer worked at McCune AV in San Fransisco. While there he developed several bi-amp and tri-amp systems that had "black box" processing. The McCune JM-3 was a tri-amped horn loaded speaker with 2 Altec 421 woofers, an Altec 290 compression driver on a 60x40 segmented horn, and 2 EV T350 tweeters. It had a dedicated amp rack with a Crown DC300 for the low, a DC150 for the mid, and a DC60 for the tweets. The crossover, system eq, and limiters were in a card frame mounted in the rack that had a panel to cover all the control. There was only a single pot on the input of each amp rack, no other controls. For its time it was an amazing speaker system and led to John Meyer founding MSL, and the Apogee 3x3.
I first ran into JM3s in the mid 1970s, the were first produced in 1971. The McCune SM3 was a 12" bi-amp cabinet with a similar drive system whose direct descendant is the Meyer UPA-1.
Stephen Kirby
How loud do they expect it?  How many of those boxes can you disconnect?
Pages: 1 [2] 3 4   Go Up
Page created in 0.047 seconds with 25 queries.
