Author Topic: Yamaha Monitor Mix  (Read 3282 times)
Daniel Ravald
    • http://www.hr-av.se
Yamaha Monitor Mix
« on: July 25, 2016, 09:58:07 am »
I'm trying to get the Yamaha Monitor Mix app to work, but it can't find the mixer. Any suggestions would be appreciated.
My setup consists of:
Yamaha CL connected to Cisco SG300. The switch is set up according to the documentation on Yamaha's website.
Ubiquiti Bullet M2. Configured as router with DHCP.
Stage Mix works great on the same iPad that I'm trying to run Monitor Mix on. I've tried using my iPhone, but the issue remains. Everything else (hard wired) on the network works just fine.
Why wont Monitor Mix find the console, when Stage Mix does? I'm thinking that the Bullet configuration might be the cause. What am I missing?
Latest firmware on all devices.
Daniel Ravald
www.ravald.com
Jeremy Bents
Re: Yamaha Monitor Mix
« Reply #1 on: September 28, 2016, 09:58:49 pm »
did you setup the 4 digit code?
did you figure this out?  we have a CL5 and CL3 both working with monitor mix.
  • Old enough to know better
  • Audio Plumber
Posting Rules
« Reply #2 on: September 28, 2016, 10:39:53 pm »
Frederik RosenkjŠr
« Reply #3 on: September 29, 2016, 01:51:02 am »
Your Ubiquiti Bullet does not have a DHCP-server. Yes, there are settings for it in the settings menu, but they don't do anything - very confusing! They're only for other products which share the UI, but they didn't bother to remove it for the products that don't have it. I'm pretty sure people have wasted 100x more time on this than it would have taken the coders to implement it right, but there we are...
So my guess is your iPad has a static IP and that's why that works, but your iPhones do not and thus do not work.
Affiliations: Danley Sound Labs, Yamaha (MI)
┬ź Reply #3 on: September 29, 2016, 01:51:02 am ┬╗
Page created in 0.06 seconds with 23 queries.
