Author Topic: DIY IEM Antenna combiner  (Read 3050 times)
Doug Boyd
« on: July 07, 2016, 07:36:44 pm »
I've used splitter/combiner units from Mini-Circuits in active & passive antenna distribution systems for wireless microphones, but would there be any issue using a 4 way power splitter/combiner such as the ZN4PD1-50 to combine 4 IEM antenna?
The 4 way splitter is 50ohm and gives > 20dB isolation between inputs.  Insertion loss appears to be just over 6dB but if used with an LDPA antenna making up that, would the combining to a single antenna be of benefit?
Doug Boyd
Stageworks Audio
Auckland, NZ
https://www.minicircuits.com/pdfs/ZN4PD1-50+.pdf
Jason Glass
    • CleanWirelessAudio.com
Re: DIY IEM Antenna combiner
« Reply #1 on: July 07, 2016, 08:55:27 pm »
It's isolation is a bit low @ 23dB for high power systems, but you might get away with it at low power (=<50mW). It would be best to test it and measure the IMD products with a spectrum analyzer before attempting to use the setup in a critical application.
Sent from my mobile phone. Please excuse the inevitable spelling and grammatical errors.
Henry Cohen
  • Westchester Co., NY, USA
« Reply #2 on: July 08, 2016, 10:11:30 am »
The 4 way splitter is 50ohm and gives > 20dB isolation between inputs.  Insertion loss appears to be just over 6dB but if used with an LDPA antenna making up that, would the combining to a single antenna be of benefit?https://www.minicircuits.com/pdfs/ZN4PD1-50+.pdf
This model has better specs, both in terms of power handling as a combiner and isolation. That said, an isolator on each each IEM output is strongly recommended.
Henry Cohen
Page created in 0.03 seconds with 23 queries.
