Thank you, TJ. I remember reading that... now.
Just put a Pass & Seymour 5-20 on the loose end of this coil. The collar on the connector is not happy with jacket's OD.
Can anyone recommend a good SEOOW + plug combo -- ie, for 12/3 + 20A use? Or the same for SOOW?
WireAndCableToGo is telling me that:
SOOW ~ 0.595 inches OD
SEOOW ~ 0.592 inches OD
So I guess I need to come up with a different connector, either way.
I've used some Hubbell 5-20 connectors on 10/3 SJOOW cable... which would work in terms of outer-diameter mating... but the lack of strain relief seems like a no-no.
I just started using a Pass and Seymour (Legrand) model PS5366-XGCM (5-20p). I'm REALLY happy with them.
http://www.legrand.us/passandseymour/plugs-and-connectors/straight-blade-specification-grade/gcm/plugs/ps5366xgcm.aspx#.V2_xdVdlmRsThere is a PDF online with many choices - straight, angled, twistlock, etc. etc. Basic black and white.
The LED indicators built in indicate:Green - Grounded and properly wired
Red or Red and Green - open ground, reverse polarity
No Indicator - Open Hot, Open Neutral, and Ground reversed.
I'm using it on 10ga SEOOW cable - No need to wrestle the 10 ga conductors or the larger 10ga jacket into the plug. Everything fits beautifully and a VERY good strain relief. 12ga will be even simpler. I like lights, and these are visible, but very unobtrusive. While it will not detect RPBG, it will detect SOME faults and give proof power is getting at least as far as that. Use NCVT and METER those outlets, though!
BTW, I also find the SEOOW slightly lighter (in weight) than the SOOW. Flexibility at room temp is consistent with the rubber SOOW.
frank
