Author Topic: help, i'm stuck in 3 way stereo  (Read 2414 times)
kwabena ade
« on: June 15, 2016, 06:39:27 am »
I'm running a 3 way stereo PA rig with no actual problems with the set. My problem is that I often play split WAV files (music track on the left channel and vocals on the right) through the system via a DJ controller. What can i change around to get a mono effect where vocal and music are represented through both channels? The DJ controller doesn't have a stereo/mono switch so i can't change it at the source. This is my first time building a PA and I'm sure it's something small and stupid that I'm forgetting.
David Allred
Re: help, i'm stuck in 3 way stereo
« Reply #1 on: June 15, 2016, 06:55:23 am »
My Traktor software has a stereo / mono selection in the Preferences / settings menu.
How does the Dj controller connect to your mixer?   A USB devise ending in stereo RCA connectors?  Just "Y" them back to mono with an adaptor.  Or is it USB in to the mixer?  Next step then is to "Y" the mixer outputs.
g'bye, Dick Rees
  • Duluth
« Reply #2 on: June 15, 2016, 07:07:26 am »
Never "Y" to combine signals.  Use a proper AV DI with stereo/mono selection.
David Allred
« Reply #3 on: June 15, 2016, 09:31:33 am »
Can you recommend one?
Mark Campbell
kwabena ade
« Reply #5 on: June 15, 2016, 04:35:40 pm »
Thanks, i will check the preferences. I didn't think of that
Gerry Seymour
    • My Professional Website
« Reply #6 on: July 04, 2016, 12:47:19 pm »
My go to AV DI is Whirlwind's PCDI http://whirlwindusa.com/catalog/black-boxes-effects-and-dis/direct-boxes/pcdi
Something like this should be in your toolbox for AV work. It solves problems, especially when others bring in their own equipment for you to connect to yours.
Gerry Seymour
Professional Trainer and Speaker
(with lighting/audio experience)
anything that moves will eventually die
anything that doesn't move is probably already dead - James Feenstra
Michael Gorecki
« Reply #7 on: August 13, 2016, 10:11:23 pm »
Radial Pro AV1 is good as well.
Page created in 0.126 seconds with 23 queries.
