Author Topic: Replace Behringer ADA8000 as channel strip for Shure wireless into LS9  (Read 5335 times)
Ray Aberle
    • Kelcema Audio
How would you fit two of those in an LS9-16?
I'd ASSume that the OP has an MY16-AT card, with two ADAT in/out sets-- that would give you 16ch of external preamps, connected to the ADA8000s. Since he only has the one slot on the board, and we know it's going ADAT... pretty sure that's the setup.
-Ray
Kelcema Audio
jesseweiss
-Ray
Sorry busy with end of year work, didn't get a chance to look at responses, but you guys are correct I use them for 16 more channels on the LS9-16.
I'll definitely look at the 8200 since it sounds like it's good enough.
I was also toying with moving the 16 lav channels direct into the board, and moving everything else (3 stage drops, 2 Shure Wireless handhelds, iPod in, etc...) to the digital channels.  Was thinking that might help with getting better sound quality and better gain control of the lav channels. Part of the sound quality issue is working with kids, but there's something else going on because even when I wear one it sounds thinner than I would expect.  Had a professional ring out the EQ already, but maybe should bring him back for more fine tuning.  Any thoughts?  Complete waste of time :)?
Mac feel free to chime in, as I believe you were the one who came to help me a few years ago when I started this journey of running sound and realized that the initial install of our system was done horribly, so you might remember the room.
George Dougherty
If you take the same lav input and cable it straight to the board inputs does it sound any better?
You should be able to do a MY16-AUD and a Rio1608-D with the LS9 though that may be out of the budget.  It could set you with an upgrade path though toward an eventual Yamaha console upgrade at some point so it may be worth considering even if it does stretch the budget now.  The QL may eventually be budget friendly for your application and the 16 channels of auto-mixing capability could be a killer feature for children's theater.
jesseweiss
Unfortunately I haven't had time to swap the lav directly to the board to see the difference.  Might try this coming week.
The upgrade stuff you mention is not in any way in any budget I would have. This is a public school.  Unless the LS dies, it's the board we're going to be using for a while longer.
Brian J Holder
Quote
If it helps, I run my radio-mics, mainly over ears, split between the ADA8200 inputs and direct board inputs. This does not cause any difficulties with sound quality, I often end up with the principals on the ADA's purely for logistical reasons. I've maxed out my inputs with 20 radios plus all the other inputs on more than one occasion.
Brian
Keith Broughton
  • Toronto
-Ray
My error. I was thinking of the back of an LS9 32 which has (I think) 2 card slots  :-[
John P. Farrell
are there other reasonably priced units similar to the 8200 that people could recommend?
I was looking at the ART TubeOpto 8, Focusrite OctoPre MkII. Above that price point it might get more challenging to get the funds.
For the $ the ADA8200 are hard to beat.  If you can deal with the name, paint job and front panel inputs I'd say they're impossible to beat!
That being said, when I was using lightpipe in and external pres to add channels to Yamaha desks regularly I bought several Focusrite MKII Dynamic pres and absolutely loved them.  Still affordable but much better S/N as well as a comp BEFORE the AD stage.  Not a great comp for musicality, but pretty cool as a limiter so you don't turn your 0s and 1s into 2s when someone unexpectedly starts screaming into a HH that has been gained up for QA or something similar.
I don't think the ART would warrant the price difference in my book.  And the reality is that they will all work just fine, especially through the desk you have.
-JF
FOH/PM Blackberry Smoke
Thomas Lamb
I run sound at the school where I teach.  A few years ago we added a set of 16 wireless Shure lavs to our setup.  They are hooked up to the Yamaha LS9-16 with digital cables from two Behringer ADA8000's.  Has worked fine, although I've felt like the sound quality from the preamps may not be that great.
One of the 8000's is shot (most likely from custodians and other staff leaving the whole system on for long periods of time unnecessarily when I didn't know and the unit overheating).  I have to replace it to get the 2nd bank of 8 lavs working again, but I'm wondering if there is a better unit I could buy?
The 8200 is affordable and supposedly overheats less frequently (and I'm going to remind people to turn it all off when not in use), and apparently has better preamps, but I'm wondering are there other reasonably priced units similar to the 8200 that people could recommend?
The Presonus Digimax is a few more dollars but has worked well for me in several very similar situations with the LS9 over the years.
bigTlamb
George Dougherty
It may not be needed, but an advantage of the ADA8200 over price competitive Presonus units would be the additional 16 XLR outs it nets you.
Page created in 0.074 seconds with 24 queries.
