Pages: [1] 2 3 ... 18   Go Down
Author Topic: If one line array is good, 2 must be better right?  (Read 36118 times)
Scott Carneval
    • Cenero Audio Visual
« on: May 14, 2016, 03:08:40 am »
Justice C. Bigler
  • Somewhere between the Atlantic and Pacific
    • My homepage
Re: If one line array is good, 2 must be better right?
« Reply #1 on: May 14, 2016, 04:30:51 am »
Does it count as a hang if the bottom cabinet is sitting on the deck? Wouldn't it just be a stack then?
Justice C. Bigler
www.justicebigler.com
Head Audio/A1 Blue Man Group North American Tour
Marjan Milosevic
    • MM-acoustics
« Reply #2 on: May 14, 2016, 06:07:56 am »
To clarify a bit what they have done there. One of the arrays is for vocals only. The band is in the other array.
But i still wonder about that bottom box aimed at the floor ;-)
Peter Morris
« Reply #3 on: May 14, 2016, 06:14:09 am »
Exactly - I think when they are flown for this show the trim height is 16m
« Last Edit: May 14, 2016, 09:25:35 am by Peter Morris »
Keith Broughton
  • Toronto
« Reply #4 on: May 14, 2016, 06:25:56 am »
3db "more" and all the extra interference for free! :o
Scott Carneval
« Reply #5 on: May 14, 2016, 07:34:19 am »
At 3am I didn't even consider that a possibility. Makes sense.
But if the audience is large enough to require two hangs of MLA they might want to get the trim height up a bit. Those first few rows (or 20) must be getting blasted!
OR, looking at it again, maybe they're just not finished raising it! Lol
Jason Raboin
    • Klondike Sound
« Reply #6 on: May 14, 2016, 07:47:50 am »
Who agrees to pay for something like this?  That's 36 more boxes plus amps and processing, not to mention motors and labor.  And for what, a marginally better better mix?  Seems like fiscal irresponsibility to me.
Jason Raboin
Partner
Klondike Sound
Peter Morris
« Reply #7 on: May 14, 2016, 07:58:55 am »
A couple of points ...
1) If you have two separate sources one for vocals and one for the band there is no interference between the two arrays theatre sound systems have been doing this for year
2) The MLA is not really a line array and because of the way it works the output from each of the transducers sums in a very constructive way. The system can achieve very precise coverage and SPL. If you have ever had a play with a MLA system (and I have been that fortunate) its like magic.
« Last Edit: May 14, 2016, 08:02:09 am by Peter Morris »
Peter Morris
« Reply #8 on: May 14, 2016, 08:05:02 am »
This is quite a big show, ... even more than 4 x SM80's would be required, and I suspect they have worked all that stuff out!
 "Rock in Rio Lisboa is the Portuguese edition of the biggest rock festival in the world."
« Last Edit: May 14, 2016, 09:27:06 am by Peter Morris »
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #9 on: May 14, 2016, 08:07:12 am »
This is quite a big show  ... even more than 4 x SM80's would be required, and I suspect they have worked all that stuff out!
Lol!
Pages: [1] 2 3 ... 18   Go Up
Page created in 0.069 seconds with 23 queries.
