Hey curious - I have an XR-18 and for some reason the same exact fx on fx1 doesn't work on any channel while the same fx on fx2 does. I've fiddled with everything. Any thoughts? Again, any input has the same issue with the fx1 and fx2. I have also ensured the fx settings on each are identical.
Thanks,
Patrick
Hi Patrick,
I don't have a good idea what's going on with your device but wanted to ask what you are using to control it?
If an iPad, be aware that the app is non-functional in mysterious ways compared to the Android. If so, try connection a laptop to your mixer and see if you can fix the problem.
I was having a problem with the iPad showing Bus 6 was set to be post-fader but it very clearly wasn't and resetting it in the iPad had no effect.
Using a connected laptop changed it to post-fader and it acted that way.
Good luck, let us know what you find.
Dan
