As I recall, early Turbo Sound speakers had XLR connectors.
I assumed anybody using them would have a case of XLR mic cables and XLR speaker cables that were of the proper gauge for speaker power use and un-shielded. It was just way too easy to mix them up.
I used to color code mine, so the speakers didn't get mixed up with the mics.
The problem with "proper sized" XLRs is that most XLRs (of the time anyway) would not accept anything larger than 18ga.
I used to hunt down (mainly at Ham fests) the Cannon Xlrs.
I would remove the rubber boot and you could get 16 ga sepaker wire in them. THey still had a screw down clamp so the cable was secure.
Switchcrafts had to clamp if you removed the boot.
The only way to get 12 ga was to go to the much more expensive NEMA AC type plugs.
I was happy when the EP connectors came out. NOW we could get proper wire into them.
