Why I posted the above is if you have or have available a set of yorkvilles you can get the same response or slightly better than the QSC subs just using the deep setting with an eq cut at 53hz.
QSC spec's 6 dbs down at 40hz. 10 dbs down at 37hz.
Yorkville's will give you 6dbs down at 38 hz maybe 10dbs down at around 33hz or so.
Splitting hairs I know but the QSC subs would be at best just a step sideways.
http://www.qsc.com/live-sound/products/loudspeakers/powered-subwoofers/kw181/Douglas R. Allen
