Author Topic: Assistance solicited. Sub-Top measurement.  (Read 2718 times)
Nitin Sidhu
  • New Delhi, India.
« on: March 16, 2016, 01:11:15 pm »
Hello all!
Getting my grip on sub-top alignment. Copy from the rational forums post. Thank for your time!
I understand that phase traces for sub measurements will often result in a U-trace. Mostly I have measured subs with the phase tracking top-bottom along the phase graph, and would align a similar phase trace of the full range speakers along it.
Here I have a U-shape trace, and am a bit stumped. Kindly advise.
The measurement was indoors in a large space. Coherence was not great, but I believe i got reasonable results. Had to use impulse to lock a delay on the sub measurement.
Image attached. Thank you all for your time.
Regards,
Sidhu
My RTA is always flat.
Nitin Sidhu
  • New Delhi, India.
Re: Assistance solicited. Sub-Top measurement.
« Reply #1 on: March 16, 2016, 01:26:05 pm »
Reading from this post :
http://forums.prosoundweb.com/index.php?topic=139234.0
Suggested to get crossover point (-6db @ 80hz in my case) to the 0degrees point by adjusting Smaart delay. In my measurement this is @ -70*
Jelmer de Jong
« Reply #2 on: March 16, 2016, 06:01:51 pm »
edit---I read it all wrong.
« Last Edit: March 16, 2016, 06:04:03 pm by Jelmer de Jong »
Timo Beckman
  • Rational Acoustics/Isemcon/Fulcrum Acoustic NL
    • Timo Beckman Geluid
« Reply #3 on: March 19, 2016, 08:29:26 am »
It looks a little bit like you're synchronizing first at the top and after that muting the tops un-muting the subs and then synchronizing to the subs.
I would expect the phase trace of the sub to go down under a angle but the phase goes horizontal before going up worth.
You first put the whole system on (tops+subs) synchronize smaart with the delay finder and after that take solo measurements of the solo bands (mid highs solo and sub solo) without synchronizing again.
You want to combine the 2 so do not re-synchronize on solo bands
Nitin Sidhu
  • New Delhi, India.
« Reply #4 on: March 21, 2016, 12:32:36 pm »
Thank you Timo!
You are correct. I am measuring individually.
ill consider that and measure again. It makes sense.
ive also had some excellent education over at the Rational forums.
Regards,
Sidhu
Timo Beckman
« Reply #5 on: March 21, 2016, 06:33:22 pm »
you might also take a look at some other web sites
http://bobmccarthy.com or buy his book (green bible;-)) :
http://www.amazon.com/gp/product/0240521560/ref=as_li_ss_tl?ie=UTF8&camp=1789&creative=390957&creativeASIN=0240521560&linkCode=as2&tag=sounddesignlive-20
https://www.merlijnvanveen.nl/en/
https://timobeckmangeluid.wordpress.com
(Video sound can be routed back to smaart or other programs but data compression/audio is a bitch specially online)
Page created in 0.026 seconds with 21 queries.
