Author Topic: wireless mic and in ear monitor combo  (Read 7039 times)
David A. Pierce
« on: January 21, 2016, 01:53:42 pm »
Can anyone recommend a wireless headset that has a mic and ear bud monitor. Body pack and the whole setup.
Pete Erskine
    • Best Audio
Re: wireless mic and in ear monitor combo
« Reply #1 on: January 21, 2016, 02:22:35 pm »
What for-Singer with in ear, monitor or comms?
For comms I use a  Sensaphonics TC1000 - pix below.  Molded in ear and nice mic all in one.
For a pack for singer and ear monitor - no one yet makes it in one piece - transmitter and in ear monitor.
« Last Edit: January 21, 2016, 02:24:44 pm by Pete Erskine »
Pete Erskine
917-750-1134
www.bestaudio.com
peter@bestaudio.com
David A. Pierce
« Reply #2 on: January 21, 2016, 02:26:52 pm »
Thank you for the info sir
Samuel Sjöbergsson
« Reply #3 on: January 21, 2016, 04:22:11 pm »
For singers with iem dpa has a few variants at http://www.dpamicrophones.com/mic-finder?filteroption=384&searchtext=In-Ear but they still need two bodypacks
Skickat från min GT-I9505 via Tapatalk
MikeHarris
« Reply #4 on: February 21, 2016, 05:18:34 am »
I have asked Sennheiser's chief wireless engineer for a 1 rackspace integrated IEM Tx and Rx in one chassis with compatible frequency co-ordination and in typical German fashion he replied "Why would you want that ?". I shook my head and his hand and said Thank You.
« Last Edit: February 21, 2016, 08:55:33 am by MikeHarris »
Simon Conway-Smith
« Reply #5 on: November 19, 2018, 05:13:42 am »
I too am looking for a single wireless bodypack unit that has separate & independent channels transmitter (for headworn mic) and receiver (for in-ear monitor), and the corresponding base station (sound desk) unit. This is to allow a performers (guitar & vocal) to be truly wireless. I already have the Samson AirLine AG1 Guitar wireless system for them.
Russell Ault
  • Edmonton, AB
« Reply #6 on: November 19, 2018, 02:06:57 pm »
I have asked Sennheiser's chief wireless engineer for a 1 rackspace integrated IEM Tx and Rx in one chassis with compatible frequency co-ordination and in typical German fashion he replied "Why would you want that ?" [...]
I suspect the reason he's sceptical is because, from an RF standpoint, this is actually a pretty tricky problem. Putting a transmitter near a receiver typically causes the receiver to desens and have reception issues. On the rack side this can be solved with proper antenna placement (although at that point your antenna rig takes up enough space that the 1U form factor is pretty moot); on the performer side things start to get tricky, especially if you want diversity reception for your IEMs (which you do).
The Telex BTR approach to this problem was to leave ~100 MHz between the RX and TX frequencies and then use filtering to reduce desens to manageable levels, but with available spectrum reductions this has gotten a lot harder. A shared antenna on the beltpack and a circulator would theoretically work, but you'd again lose diversity reception (and circulators tend to be delicate and expensive).
Probably the best solution is the most common: put a large bag of meat between the RX and TX beltpacks to attenuate the TX signal at the IEM RX. Of course, this means using a single beltpacks for both isn't possible.
Basically, as I understand it, what you're looking for doesn't exist because of physics...
-Russ
Jerome Malsack
« Reply #7 on: November 20, 2018, 09:24:14 am »
True but with the 1/4 wave rule you will only need 8 inchs in uhf to have the separation between the transmitter and receiver.  You can add in the body of the talent to help by placing the IEM high left side breast pocket or area.  and the typical wireless mic on the back right side like the guitar player.   Then setup the antenna for the FOH in the correct places.  receivers antenna around the back line and the IEM from the FOH  front of stage onto the stage.
Jean-Pierre Coetzee
  • Gauteng, South Africa
« Reply #8 on: November 20, 2018, 01:55:10 pm »
I believe this is exactly what Russell said. The issue is TX and RX in one pack. In some countries this is feasible. We for instance have the 600 MHz and 800 MHz available which means you can put one in each band and filter the RX to exclude the other however in the USA you will probably need one to run digital VHF and the other in the available UHF band and even then you will need to run at pretty low power.
Audio Technician
Word & Life Church
- Ivan Beaver
Henry Cohen
  • Westchester Co., NY, USA
« Reply #9 on: November 20, 2018, 10:05:25 pm »
Let's not forget that wireless intercom has been doing this for years, the Telex BTR being the obvious example. In the UHF BTR-800, band separation is just under 100MHz; in the VHF BTR-300, separation was as little as 36MHz.
Quote
Why digital VHF?
No question putting both a very high audio quality transmitter and receiver in one small-ish pack is a challenging effort, and one that is being pursued. A couple of paradigm shifts are coming.
Henry Cohen
Page created in 0.085 seconds with 24 queries.
