Author Topic: WinRadio WR-305e scanner question.  (Read 2005 times)
Kevin Maxwell
« on: December 23, 2015, 03:47:14 pm »
I am trying to get a usable CSV file out of a WinRadio WR-305e scanner. That I will then import into Shure Wireless Workbench V6. I assume that I am doing something wrong. In the CSV file I don’t get the level of the frequencies that I get a hit on, at least not anywhere that I can see. They should be in the format of like (-45). Also the frequencies I am getting are 9 characters long without the appropriate decimal point for Mhz. so 450125000 instead of 450.125 and I can’t figure out how to parse that in Excel. I assume that I will have to edit out the header and other data that isn’t needed.
Does anyone have an idiots guide to making this work. I have spent hours trying to get this to work properly and I am lost. Is there some selection I don’t have set right?
Kevin Maxwell
Re: WinRadio WR-305e scanner question.
« Reply #1 on: December 23, 2015, 04:47:58 pm »
Well I figured out how to get the frequency in the format I need now I am just missing the db level of each frequency, signal strength.
I just needed to format the cells as a number with 3 decimal points and divide the 9 digit number by 1,000,000. It was so easy but I was thinking this shouldn’t be necessary, the CSV scan file should be in the right format to start with.
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #2 on: December 23, 2015, 04:56:07 pm »
Can you post a sample of that data you are getting?   I'm not sure how to get the missing dB level if the program isnt spitting it out.
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
Kevin Maxwell
« Reply #3 on: December 23, 2015, 08:45:21 pm »
It looks like this. The -95 is the Level squelch value. The second number the 9 digit one is the frequency, I was scanning local radio stations to test things.I have a feeling I don’t have it configured properly so it will spit it out. All indications are that it is supposed to be capable of putting out the proper data. But nowhere can I find detailed instructions regarding how to configure it to do that. I can see it showing the signal strength in the WinRadio software as it finds frequencies.
"Number","Frequency","Bandwidth","IF Shift","reserved","reserved","reserved","reserved","reserved","Groups","Hotkey","Lockout","Priority","Level squelch value","Secondary squelch type","Secondary squelch value","Mode","Callsign","Comments"
"900","105300000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"901","107825000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"902","107850000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"903","107875000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"904","107900000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"905","107925000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"906","107950000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"907","107975000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"908","108000000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"909","105300000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"910","107775000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"911","107800000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"912","107825000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
"913","107850000","10000","0","","","","","","16","0","0","0","-95","","","FMN","",""
