Pages: 1 [2] 3 4 ... 7   Go Down
Author Topic: Factory Speaker Specs & Grilles  (Read 15137 times)
Re: Factory Speaker Specs & Grilles
« Reply #10 on: December 03, 2015, 02:08:37 am »
I thought it was more like the Harley-Davidson crowd immediately taking off the mufflers and changing the exhaust pipes . . . .
On many carbed cars of the 70's you could also flip the lid.  Pull the vac. hose off the ER valve and stick a golf tee in.  Crank up the timing a bit and put some bigger jets/metering rods in and you could really wake up a smog motor.
Sent from my SM-T800 using Tapatalk
Bob Leonard
  • Boston, MA USA
« Reply #11 on: December 03, 2015, 08:04:56 am »
Or you could remove the valve on a small block Chevy and block it with a plate.
I think I'll pull the grills off of my cabinets. That way the crowd will have a target for throwing shit at, it will make it easier to punch holes in the cones while moving them, and if I still owned a cat it would make it much easier for it to piss on them.
BOSTON STRONG........
Proud Vietnam Veteran
« Reply #12 on: December 03, 2015, 08:28:06 am »
Of course some speakers are easier to tear up with the grills removed than others---  ;)  ;)
In some cabinet the drivers are not easily accessible and are more protected.
John L Nobile
« Reply #13 on: December 03, 2015, 09:33:57 am »
Good points and if there was any chance of those things happening I wouldn't take the grills off either.
But mine are permanently flown and not in a bar.
Keith Broughton
  • Toronto
« Reply #14 on: December 03, 2015, 10:15:58 am »
Look even better if they let me paint them red or orange.
That's a matter of opinion John ;-)
I see some speaker grills that are honeycomb shaped holes and look like they provide the best open ratio.
Jeff Baumgartner
« Reply #15 on: December 03, 2015, 10:38:09 am »
Good timing. I just took the grills off my SH96HO's. Like an hour ago. Been meaning to do that for a while. Next shows on Friday and I'm expecting more hi end. I think they look better too. :)
If I did that to mine, I would have birds nesting in them. Then PETA on me for when the birds died after they were fired up.
Steve M Smith
  • Isle of Wight - England
« Reply #16 on: December 03, 2015, 11:32:08 am »
I thought that too... Until I tried it out on CAD...
This is with a 6mm wide aperture and 2mm of material between apertures.
If I offset the apertures out by 0.5mm keeping the spacing the same (increasing the aperture width to 7mm and reducing the solid material to 1mm wide) I get 75.56% for both.
Steve.
Keith Broughton
  • Toronto
« Reply #17 on: December 03, 2015, 12:55:44 pm »
Steve.
Interesting point. I don't see many, if any, square hole speaker grills.
It is my understanding that with a honeycomb, the strength of the design allows for thinner material between holes.
That would allow more open space per square inch.
Jerome Malsack
« Reply #18 on: December 03, 2015, 01:33:56 pm »
You could always adjust the flat space that is the problem to be less flat and make it a triangle.  /\  So it will not bounce back as easily.   That would be a very costly grill !
« Reply #19 on: December 03, 2015, 02:05:35 pm »
When I designed the speaker grille for the bottom of my drum tuner, protection and effectiveness were both important.
At the frequencies I am dealing with the modest grille blockage was not an issue, and effectively transparent to the drumhead/speaker acoustic system. For my customer base (drummers) leaving the speakers exposed would be a bad idea.
Pages: 1 [2] 3 4 ... 7   Go Up
Page created in 0.046 seconds with 23 queries.
