Author Topic: Yorkville Subs  (Read 2537 times)
Bernard Fernand
Yorkville Subs
« on: October 31, 2015, 02:40:23 pm »
Hey guys can you help me out? I would like to know what subs I should put over 6 Yorkville PSA1 and how much. Oh and if they're unpowered which amp best suits the subs?
Paul G. OBrien
Re: Yorkville Subs
« Reply #1 on: October 31, 2015, 04:24:39 pm »
The obvious answer would be 6 Yorkville PSA1s subs or maybe 4 PSA2s boxes as a bare minimum but you could double or tripple that depending upon where and for what you are using the rig.
« Last Edit: October 31, 2015, 04:26:57 pm by Paul G. OBrien »
Richard Turner
Re: Yorkville Subs
« Reply #2 on: November 05, 2015, 09:18:43 am »
Wouldn't even look at the 2x12 sub if you need any amount of low end. might be ok for jazz AC/easy listening or conference work but if you need to replay dance or pop canned music or live rock bands the 2x15 one per pair if tops is the way to go.
In all honesty though once you go past 4 tops it might be worth looking at a real line array system as rigging 3 or4 boxes becomes involved and expensive for the gain you get if using for a portable PA
4 tops 2 dual15 subs makes an adequate system for most small jobs you can put 2 tops on a heavy speaker stand roll into the venue and have audio up in 20 mins. the Long-Mcquade stores up here in canada use them extensivly in their rental systems and they are quite idiot proof, very close to dj proof boxes.
If you like the yorkville have a look at vtcproaudio, same stuss but done with more pro cabinet finishes and better hardware as well as a real line array.
Looking at retiring. Local PA market has shrank to 2 guys with guitars and bose l1 compacts or expecting full line array and 16 movers on stage for $300... no middle left going back to event DJ stuff, half the work for twice the pay.
Mark Oakley
    • Oakley Audio
Re: Yorkville Subs
« Reply #3 on: November 05, 2015, 10:53:22 pm »
Priceless!
-Mark
Brian Dill
Re: Yorkville Subs
« Reply #4 on: November 16, 2015, 10:07:56 am »
4 LS2100PB's; And there will be more than enough controllable low end. The PSA subs' output is less than desirable.
Page created in 0.026 seconds with 21 queries.
