So what you would like to see, and would consider to be "accurate" would be a smoothed response measurement (since that/those peaks should get eq'd out anyway) but you also think it's not misleading to fail to disclose that smoothing?
Just to help inform people, there are several different ways to "smooth" a freq response.
The first is to apply a certain amount of smoothing to a graph.
This is what people normally expect.
HOWEVER- you can have a very smoothed graph WITH NO smoothing applied after the measurement.
This is simply done by reducing the data points that were used to get the graph. With fewer data points, the peaks and dips get "absorbed" into the average.
So some people like to say they applied little or no smoothing-but yet there was nothing to be smoothed in the first place.
If you look closely at the Danley freq response graphs, at the very top will will see the data resolution used to get the graph.
In almost every case (some early models it may be different), you will see that I tried to go a full decade below the expected "-3dB" point.
So for a 40Hz box the resolution is 4 Hz. For a 30Hz box it is 3 Hz.
The finest resolution I can get with TEF (Danley measurement system of choice) is 2Hz. So for a 10Hz box like the DTS10-it only 2Hz resolution. Which is not enough to accurately describe what is happening down at 10Hz. But is it all we have.
So ONCE AGAIN- you HAVE to look closer at the data you are given to see what you are really dealing with.
If all you see is a graph that was generated on a computer and looks nice and smooth-with no details, who knows where it came from.
Danley does not try to hide anything-and how we get the data-the resolution etc is out in the open.
People should ask the same of other manufacturers.
Since there are no standards that manufacturers MUST abide by, each manufacturer is completely free to state whatever they want to-true or not.
But the REAL problem I see is not the manufacturers lying-but as them not telling the TRUTH-as YOU (the consumer) would like to believe.
For example. With subs. VERY OFTEN there is a peak in the freq response much higher than the "sub" freq range. I call that below 100hz.
So they will make the "max SPL" claim at this high freq.
Will the speaker actually produce this SPL-YES. So they are NOT lying.
But what YOU want to know is how loud will it go in the INTENDED freq range of usage.
That max SPL number given IS NOT for that range-so you do not get the performance you "thought" the spec was giving you.
The same thing goes for full range cabinets. Unprocessed may cabinets with a large diaphragm HF driver will have a LARGE peak around the 1k-2K range, This can result in some VERY IMPRESSIVE SPL numbers.
But you would NEVER use the cabinet without that peak being brought down 10dB or so-to equal the rest of the freq response.
So while the cabinet will actually PRODUCE that SPL, it is unusable in terms of the rest of the freq response.
BUT YET people will buy the cabinet with the high SPL simply "thinking" that the WHOLE response will equal it.
Of course the people who "play those games" do no actually show any data to support the claims- you are just supposed to "believe" them because they are so "famous and accepted"-how could they lie?
Well all you have to do is to buy one of the cabinets and ACTUALLY TEST IT yourself and see.
But most people just want to "believe", rather than actually confirm.
Lying is one thing-deception is quite another. Most people are deceived, but then later think they were lied to.
The truth is not always as we would like to believe.
