Author Topic: Windscreens for lectern mics  (Read 3516 times)
Riley Casey
« on: October 15, 2015, 03:28:58 PM »
I'm looking for an improvement on the Shure windscreens for the MX412 style mics.  I've got more than sixty in stock  and a few seem to have acquired a much nicer, elongated windscreen with almost twice the foam in front of the capsule as compared to the Shure stock windscreens.  Trouble is I don't know where the better windscreens came from.  I'm looking at the Windtech 1400s http://www.bhphotovideo.com/c/product/298943-REG/WindTech_1412B_1400_Series_Replacement_Windscreen.html as a possible candidate.  What are you using for your small capsule mics?
( also, whats the code for turning text like "windtech 1400" in to a link since the insert url button in the formatting option for posts isn't doing it? )
Scott Helmke
Re: Windscreens for lectern mics
« Reply #1 on: October 15, 2015, 03:56:56 PM »
On the MX gooseneck mics we use the stock windscreen.
But for dedicated lectern mics instead of bulk conference mics we use the Shure A99WS, which is a ball-shaped windscreen that fits onto that kind of mic nicely.
« Last Edit: October 15, 2015, 05:47:10 PM by Scott Helmke »
Keith Broughton
  • Toronto
« Reply #2 on: October 15, 2015, 04:51:48 PM »
BH Photo has a huge selection of windscreens.
Josh Millward
  • Meridian, MS
« Reply #3 on: October 15, 2015, 05:12:35 PM »
You mean like this:
WindTech 1400
Take the spaces out of this text string:
[ url=http://www.bhphotovideo.com/c/product/298943-REG/WindTech_1412B_1400_Series_Replacement_Windscreen.html ]WindTech 1400[ /url ]
Start with the Left Bracket: [
Then put in the start url message: url=
Then you put in the actual URL
Next is the Right Bracket: ]
Insert the text you want to display
Another Left Bracket: [
End url message: /url
And finally the last Right Bracket: ]
What I usually do is type the text I want to display, in this case: WindTech 1400
Highlight the text with your mouse, then click the "Insert Hyperlink" button.
This will give you (spaces added to keep it from showing as BBCode) [ url ]WindTech 1400[ /url ]
Then insert "=web-link" after the first tag to get something like this (again, spaces added to break the BBCode):
So now that shows up thusly:
WindTech 1400
Josh Millward
Jason Lavoie
« Reply #4 on: October 16, 2015, 08:47:58 AM »
http://www.bhphotovideo.com/c/product/97641-REG/Shure_A99WS_Ball_Foam_Windscreen_f_SM99.html
This isn't elongated, but it is from shure so it should fit right.
There's also this one that locks on with a set screw
https://www.google.ca/webhp?sourceid=chrome-instant&rlz=1C1CHNU_enCA326&ion=1&espv=2&ie=UTF-8#q=shure+a412mws
a bit more expensive but a different look.
Also, the windscreen's effectiveness is reduced if it is pushed all the way on. ideally it should be backed off a bit to leave a gap between it and the capsule
Jason
Keith Broughton
  • Toronto
« Reply #5 on: October 16, 2015, 12:29:17 PM »
Jason
That looks like a good one! Must get one to try.
If you look at the big budget awards shows, they seem to have much larger windscreens than we usually have on our corporate lecterns.
I wonder if they have figured out something.... 8)
drew gandy
  • Chicago and burbs
« Reply #6 on: October 17, 2015, 08:57:55 AM »
Is there a chance that your mics ended up with the wireless windscreens?  They both have the plastic frame that allows them to snap on but the wireless one has significantly less foam and is therefore shorter.  They also work poorly on desk mics where the mic is much more likely to get direct plosives as compared to a tie mic.
I have not done objective studies but I think the EV Polar Choice windscreens (with the cross holes in them) as well as the Audio Technica windscreens (with the recessed "ring" around the foam just above the capsule) seem to work better at killing plosives than the regular Shure windscreens.   The stock screen is usually ok but every once in a while I get a doctor who really knows how to bottom out the diaphragm.
Also, I just emailed with Shure a few weeks ago about part of this topic and, as Jason mentioned, the windscreen's effectiveness is better if it's pushed on to the first click which leaves some air between the foam and the capsule.  Interestingly, it apparently doesn't compromise response or polar pattern to push it all the way down.  I find these screens pushed all the way down very often and fixing them has become one of my neurosis (like when I don't step on cracks in the sidewalk;).
Arrogance is usually far worse than ignorance. But every once in awhile they swap places.
George Dougherty
« Reply #7 on: October 19, 2015, 01:34:59 PM »
The ones I found and picked up for Sennheiser and Shure gooseneck mics were packaged by Audio Technica. It's quite a bit larger than the stock from either but sounds similar to what you describe.
AT8102 is the model I think.
« Last Edit: October 19, 2015, 01:38:16 PM by George Dougherty »
Jim Wilkens
  • Marblehead MA
« Reply #8 on: October 21, 2015, 08:56:44 AM »
We use an Audio Technica windscreen. It fits perfectly, looks good and is a big improvement over the Shure.
http://www.sweetwater.com/store/detail/AT8153
On our Countryman lectern mics we add a Shure SM81 windscreen over the existing one.
Page created in 0.028 seconds with 17 queries.
