Author Topic: 70V system amp recommendation  (Read 5268 times)
John L Nobile
« on: September 04, 2015, 12:02:53 pm »
Our Crown CE1000 has gone into constant protect mode. I had a spare that was repaired a while back but I'd like to order something a little newer for a more permanent solution. It drives a 70V system with speakers all over the hotel and has been working fine for years.
I have absolutely zero experience with 70V systems and after figuring out where all the wiring was ending up, I was surprised to find only 1 amp driving all those speakers. 4 zones covering a large restaurant, a bar, 2 hallways and the main lobby.
What amps have you had good results from? I'd like something with terminal strips for inputs and I have some terminal strip to Speakon adapters from the current system.
Thanks
Lee Buckalew
  • St. Louis, MO area
    • Pro Sound Advice, Inc.
Re: 70V system amp recommendation
« Reply #1 on: September 04, 2015, 12:09:50 pm »
Thanks
John,
I have had great results from QSC CMX series.  Very cost effective and have been bulletproof.
Look at the series carefully as the smaller models must be operated in bridged mode for 70 volt operation (meaning they are also single channel at that point).
There are many other very solid choices, these have just become my go to, no frills amps that are cost effective and do what they claim.
Lee
Lee Buckalew
« Reply #2 on: September 04, 2015, 01:02:26 pm »
Literally anything but a CE1000...   ;D
There are a number of serious companies making professional 70V amps.
Did the CE1000 have an external step up transformer? Or drive output bridged?
John L Nobile
« Reply #3 on: September 04, 2015, 01:10:24 pm »
It was driven stereo into 2 external transformers.
I see why you said anything but. There used to be 5 CE1000's in the rack. I gave 3 to a buddy and he got them repaired and the one left as backup didn't work wither. 5 out of 5 went down.  The one I have working now is one that my buddy had repaired.
John L Nobile
« Reply #4 on: September 04, 2015, 01:11:43 pm »
John,
Lee
Thanks Lee. I'm going to look at those right now.
Scott Carneval
    • Cenero Audio Visual
« Reply #5 on: September 04, 2015, 03:19:33 pm »
Thanks
QSC makes a great amp.  So does Ashly Audio.  Unless you have an impedance meter (different than a multimeter) you won't be able to calculate the load that this amp is currently driving.  So just make sure you get something as big or bigger than the current amp.
Lee Buckalew
« Reply #6 on: September 04, 2015, 03:37:40 pm »
I'll also second Scott's comments on Ashly.  Great amps and a very responsive company especially regarding tech questions.  Ashly has become an entry price go to with built in DSP (they offer non-DSP versions as well).  Very capable.
Lee
Lee Buckalew
David Buckley
« Reply #7 on: September 04, 2015, 03:49:10 pm »
There is essentially three ways of doing 70V systems, buying an old-school "public address" style amplifier that says "70V out",  usually from a manufacturer that rock and roll and theatre types wouldn't recognise as a mainstream name.  Then there is a "normal" amplifier with a common name in these parts, with an external transformer to convert 4 ohm to 70V.  Thirdly, a "normal" amplifier that can deliver a bit over 1200W into 4 ohms is producing an output of 70V directly, and this can drive a 70V line directly.
To decide, figure out how much power you need, which is the sum of the selected output of all the speakers.  Most 70V speakers are settable as to their power output, with "taps" usually something like 0.5W, 1W, 2W, 4W.  Add it up.
Then determine the costs of each of the options.  As the power goes up, the third option usually becomes cost very effective.
Note that if one chooses the third way, the actual output power of the amp is determined by the load; the signal lamps on the amp might be showing full output just under clip, but the power is determine by the load.  If there is only 100W of speaker load connected, then that is what the amp is delivering, even though the blinkienlitz look like that 1500W amp is running at full tilt.
As a final note, some 70V systems are part of a fire alerting systems; do not tool with these, they need specialist equipment which is monitoring the integrity of the system.
For non-USA folks, exactly the same applies to 100V systems, only the third option needs an amp of about 2500W into 4 ohms.
« Reply #8 on: September 04, 2015, 04:34:35 pm »
I forgot the obvious question.. does the CE1000 stay in protect mode, when the load is removed?
It sounds like the CE1000 was working for years (remarkable enough), and he already has 70V transformers, so I would just look for a new general purpose amp that doesn't suck.
I would look for something with similar power to the CE1000 (at the impedance tap it is driving the 70V transformer), and better yet with a built-in HPF (70V systems don't like bass).
John L Nobile
« Reply #9 on: September 04, 2015, 07:01:29 pm »
It does not go into protect mode without the load. At first I assumed that it was a short in the system. To check that, I hooked up a single JBL cabinet. It went into protect mode right away.
I'm looking at the QSC CMX500va
http://qsc.com/products/Power_Amplifiers/Cmxa_Series/CMX_500Va/
Think that would work out well for me?
Page created in 0.04 seconds with 23 queries.
