Thanks a ton guys, the anti static solution that dick and Bob mentioned appears to have done the trick.
I just Cleaned off the connectors with contact cleaner as well and will try the ground line as well but so far all seems good.
I had a situation once where the only solution was to use the anti static spray, during the dry season. I tried everything else I could think of and nothing else worked. It would be interesting to see what the differences are between the 2 rooms that you mentioned. It might be a slightly different carpet on the stage in each room. It could be a slight difference in the HVAC between the 2 rooms making one drier then the other.
I was in one room once where they have a static problem and you could walk across the carpet and touch wood and get a shock.
Just be careful to not use too much of the spray that you have, some solutions can make the carpet slippery.
