Author Topic: UR4D, UR1 dropouts UR2 totally stable?  (Read 5056 times)
Art Williams
« on: August 04, 2015, 03:36:39 pm »
Hey I hope someone can help a little bit. Last week I was using my normal UR4D setup, Paddle antennas, etc. while using the Handheld transmitter I had full RF blue lights and all no problems audio worked great no issue. When I switched over to using a Beltpack transmitter with an XLR to TA4F I kept having audio dropouts. again I had great RF but the audio would just drop. I did notice as I was having drops the lower section of the receiver display (tonekey area) was changing from Nm to O and I saw a +5 at some point. I've actually never run into this situation so I'm not sure what to do to keep the issue from happening again. I don't believe I was over driving the transmitter so I don't know what causes those changes to occur in the tone key section.
Any help or insight can help
Thanks
Art
Henry Cohen
  • Westchester Co., NY, USA
Re: UR4D, UR1 dropouts UR2 totally stable?
« Reply #1 on: August 04, 2015, 03:56:41 pm »
Did you remember to turn off the hand held before switching to the belt pack? Sounds like there were two transmitters on or near (within 100kHz) the same frequency.
Henry Cohen
Art Williams
« Reply #2 on: August 04, 2015, 04:32:58 pm »
No, no intermod issues and no HH and BP we're not on at the same time.
Henry Cohen
« Reply #3 on: August 04, 2015, 06:49:57 pm »
Mic element known to be good? A bad mic cable would tend to make rather noticeable noise, but should be checked anyway.
Did the pilot tone settings of the belt pack match that of receiver?
Batteries new?
Was the mic a dynamic or condenser?
Henry Cohen
Jason Glass
    • CleanWirelessAudio.com
« Reply #4 on: August 05, 2015, 08:32:29 am »
Thanks
Art
I have experienced a few instances of this sort of thing and the issue turned out to be a broken UR1 antenna connector pin.  They were barely making contact with the part of the pin stuck in the socket.
Art Williams
« Reply #5 on: August 05, 2015, 03:17:35 pm »
Plausible but I tried 3 different belt packs and 3 different receivers
I'll check all the BP antenna connections.
Jason Glass
« Reply #6 on: August 05, 2015, 03:32:33 pm »
Hmmm. Have you tried toggling the UR1 RF power up or down?
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #7 on: August 05, 2015, 03:33:11 pm »
What were you feeding into the XLR?
brian maddox
bdmaudio@gmail.com
Scott Helmke
« Reply #8 on: August 06, 2015, 12:22:51 pm »
I'll bet a jelly doughnut that it's the XLR to TA4F adapter cable. They don't use the power from the beltpack, which means there won't be a pop in the audio if the cable is intermittent.
  • Old enough to know better
  • Audio Plumber
« Reply #9 on: August 06, 2015, 12:25:51 pm »
Hmmm... What was it that was the same on all the testing of belt pack transmitters?
Page created in 0.049 seconds with 23 queries.
