Author Topic: 15 Amp Circuit Breaker Tripping  (Read 6471 times)
Steve M Smith
  • Isle of Wight - England
Re: 15 Amp Circuit Breaker Tripping
« Reply #10 on: August 05, 2015, 08:52:00 am »
It opens up the possibility of grossly overloading extension cables by uninformed users.
With ours, you can potentially plug an infinite number of appliances into one socket and have it all protected from overload.
So although a setup like this might look a bit scary:
As long as the total load does not exceed 13A (3000w) all will be o.k.  And if it does, a fuse will blow somewhere.
Steve.
« Reply #11 on: August 05, 2015, 09:04:37 am »
You make a good point.
Most people don't understand you can't have a toaster, kettle and microwave running at the same time on a 15 A cct.
Thankfully, cct breakers work to save them :)
I bought a home with the bifecta of things home inspectors don't want to see:  Zinsco and Federal Pacific breaker boxes. FP got sued out of existence because their breakers don't trip at 400% of load over 20 minutes.  The Zinsco ("Magnetrip") breakers will trip (quickly, I might add) but the contacts weld themselves to the bus bars.  I'll take the Zinsco...
Since I live alone and have some semblance of electrical responsibility I avoid overloading circuits, but as Mike's example shows, too many folks just plug stuff in without regard to power consumption.  Electricity has been made so relatively safe that it is treated with disregard by the public.
Keith Broughton
  • Toronto
« Reply #12 on: August 05, 2015, 09:34:26 am »
Steve.
It does look scary but makes sense.
If the same thing were done here, there is still a breaker at the feed end that would trip if the total load was too great.
The problem here is that someone could load all that on an 18 G  cord!...and run it under a carpet  :o
Jonathan Johnson
« Reply #13 on: August 05, 2015, 12:26:32 pm »
Steve.
Most commercial facilities (from offices to factories) in Washington state -- I don't know about other states -- have an annual inspection by the fire marshal or fire department. The inspector will cite a facility for having an outlet strip plugged into an extension cord or another outlet strip. (The outlet strips with overcurrent protection are usually acceptable to the inspector. While most outlet strips have overcurrent protection, not all do. Those splitters that hang off the outlet almost never have overcurrent protection.)
They really don't like extension cords where it's obviously there more-or-less permanently -- they consider anything other than "using it right now for a portable tool" to be permanent.
However, those citations rarely result in a fine. Usually, the problem is corrected at time of inspection. If not, the facility is given a window of time (usually a week to a month) to clean things up, at which time they will receive a followup inspection. If not cleaned up by the followup inspection, then they may receive a fine.
People in the United States don't like inconvenience. If a fuse -- rather than a circuit breaker -- was present in every power plug, someone would probably sue the manufacturer for failing to provide for their convenience. And being able to overload a cord would be considered a convenience. Not to mention that 80% of Americans would be too stupid to figure out how to replace the fuse, so they would just throw the thing out.
Of course, Americans like to sue on the drop of a hat, so if their house burns down because of an overloaded, unfused cord, they'll sue the cord manufacturer anyway. And they'll probably sue the manufacturers of each item plugged into that cord. And the electrician who wired the house. And the power company. And the store that sold them the cord. And the fire marshal for not inspecting their facility in a timely manner. And the site hosting the online forum where they received bad  advice. (But they can't sue joe5479, only because they can't figure out who the real person behind that avatar is.) After all, it's never their own fault. Sigh.
Steve M Smith
« Reply #14 on: August 05, 2015, 01:11:41 pm »
These used to be popular here too:
This allows four plugs into one socket... and yes, it also has a fuse!
Steve.
Jonathan Johnson
« Reply #15 on: August 05, 2015, 02:25:09 pm »
Steve.
The ONLY plugs in the USA (in common use, anyway) that are fused are holiday light strings. Probably because the wires are about the size of a carbon nanotube, but they are designed so that the user can daisy chain an infinite number of strings together. They are like extensions cords with little tiny lights along their length.
Stephen Kirby
« Reply #16 on: August 05, 2015, 06:46:16 pm »
Which people attach to their rooflines with staple guns.   ::)
Page created in 0.04 seconds with 22 queries.
