Pages: 1 [2] 3 4   Go Down
Author Topic: Tapped Out  (Read 9507 times)
TJ (Tom) Cornish
  • St. Paul, MN
Re: Tapped Out
« Reply #10 on: July 30, 2015, 04:05:50 pm »
How can you see the nut, it must be on the other side of the wire.
Pretty sure he means the blue one.
Steve Alves
  • South Florida
    • South Florida Sound
Re: Tapped Out
« Reply #11 on: July 30, 2015, 11:10:51 pm »
I don't get it, if you are going to do something that stupid, surely there was a lug somewhere in the box that they could have jammed that wire into. It would have been just as bad but I would have rather seen a double lug then that.
« Last Edit: July 31, 2015, 07:49:49 am by Steve Alves »
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
Jeff Bankston
Re: Tapped Out
« Reply #12 on: July 31, 2015, 02:49:44 am »
I don't get it, if you are going to do something that stupid, surely there was a lug somewhere in the box that they could have jammed that wire into. It would have been just as bed but I would have rather seen a double lug then that.
yep just as bad !
                         http://www.youtube.com/watch?v=rSjK2Oqrgic
Mike Sokol
Re: Tapped Out
« Reply #13 on: July 31, 2015, 06:43:51 am »
yep just as bad !
As a teachable example for those who don't know, I'm sure you all realize that that if the small wire shorted out somewhere, there's no circuit breaker to trip. And it could easily be asked to pass hundreds of amperes of current, causing it to vaporize and making something called an arc-flash blast. That's WAY dangerous since the resultant fireball is hotter than the surface of the sun moving at faster than the speed of sound. It's an electrician's worst nightmare. https://www.youtube.com/watch?v=dPJtknGmsys
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
David Allred
Re: Tapped Out
« Reply #14 on: July 31, 2015, 08:42:18 am »
The first problem is the wire is wrapped the wrong way around the screw.
Only on PSW!   Ha.
Mike Sokol
Re: Tapped Out
« Reply #15 on: July 31, 2015, 10:00:40 am »
Only on PSW!   Ha.
The devil is in the details.
Mike Sokol
www.NoShockZone.org
Stephen Kirby
Re: Tapped Out
« Reply #16 on: July 31, 2015, 12:44:00 pm »
The wire nut is a size too small?
Or the strip is too long.  Love the backwrap on the screw too.
Mike Sokol
Re: Tapped Out
« Reply #17 on: July 31, 2015, 02:50:30 pm »
Ummmm..... I think we're way beyond discussing best practices for wire nuts. But since we're there, I like to do mine twisted and taped.
Mike Sokol
www.NoShockZone.org
Stephen Kirby
Re: Tapped Out
« Reply #18 on: July 31, 2015, 04:50:03 pm »
I guess they don't make these in 000 size.   ::)
On a slightly more serious note;  Mike, what is your opinion on the "waterproof" wire nuts.  I've used them on my sailboat but I see them in the hardware stores as if they were an improvement for home wiring.
I've long thought that whoever wrote the NEC had stock or relatives in the wire nut industry.  As a manufacturing engineer with background in weapons spec electronics, that's probably the last way I would choose to hook wires together.  Especially in things like putting two duplex outlets in a box as opposed to using both terminals and the tie bar.
Mike Sokol
Re: Tapped Out
« Reply #19 on: July 31, 2015, 05:45:14 pm »
Others on this forum are likely more involved with wire nuts, but I've seen these waterproof nuts in a few stores and always passed over them. For serious waterproofing we always used self-sealing electrical tape which makes its own gooey sealant. Of course it's nearly impossible to get the mess apart a year later, but I'm pretty sure it's not going to leak. Of course, anything like waterproof wire nuts or self-sealing tape is not a substitute for a weatherproof enclosure, but it's certainly a good backup if the enclosure seal fails for any reason.
Mike Sokol
www.NoShockZone.org
Re: Tapped Out
Pages: 1 [2] 3 4   Go Up
Page created in 0.046 seconds with 23 queries.
