Pages: 1 2 [3] 4   Go Down
Author Topic: Condenser mics for live group vocals  (Read 8016 times)
Scott Wagner
  • Richmond, VA
Re: Condenser mics for live group vocals
« Reply #20 on: July 26, 2015, 08:46:20 pm »
I was simply surprised at how easily lavs feed back in comparison.
Why are you surprised at this? Lavs are still microphones, and subject to the same laws of physics. Instead of a handheld an inch or two from the source, you have a lav six inches or more from the source - so you have to increase the gain to get the same result. If you use a handheld at the same distance, you'd have the same issue. I suggest that you do some more studying before publicly questioning someone who's been doing audio for longer than you've been breathing. Dick is spot-on with his statements.
Scott Wagner
Big Nickel Audio
g'bye, Dick Rees
  • Duluth
« Reply #21 on: July 26, 2015, 08:54:01 pm »
Thanks, Scott.  I question all statements which (when read by a casual reader looking to learn or someone posting with a specific question) may cloud the issue or suggest unsound or impractical ideas.  It has little or nothing to do with the person who posted the incomplete or inaccurate info.  It's all about keeping it real for those who sincerely want to learn.
Nathan Vanderslice
« Reply #22 on: July 26, 2015, 09:26:41 pm »
With 16 lavs available on "human mic stands", you might consider adding one or more of the mic'd up kids to the smaller groups and double up your lav use.  If you want to get fancy and these are real clip-on lavs and not earsets, it's quite easy for one of the stage moms to reposition the lav to the collar at the back of the neck for use as a group pick-up.  The "mic stand" can kneel in front of a group of 3 or 4 kids and pick up pretty well.  No hasle to set the "stand" anywhere you want and you can even have the group migrate around the stage and have the mic available to them.  Again, if you want to get fancy and have the channels, you can split the feed of any such mics into two separate channels for processing and grouping according to the function...individual or group.
No need to buy more stuff.  Double use what you have.
Been there, done that.
Great point! One common practice I was taught was that when you have two people close to each other on the stage with "body" mics, is to use one mic for both of them as you can have phase problems if both mics are up (which give you "mud"). One bit of caution I would throw in here is the use of overhead mics. Whether they are mounted to scenery, or hung from the flies, it's generally a bad idea. You might be able to get away with it using cardioid mics., but even then, you're likely to pick up reflected sound from the stage and flies, especially if you use omni mics as some who are not very well educated in sound reinforcement are likely to do. Two other things, one, they look ridiculous hanging there, and two, the odds are that the kids won't get picked up well because they are under the mics not in front of them, and it's likely that they're going to be too high to be any good.
jesseweiss
« Reply #23 on: July 26, 2015, 09:32:09 pm »
Okay I'm getting confused, and since it was my original question I'm hoping to get clarification.
After research it is my understanding that condenser mics are capable of more sensitive and are also intentionally designed that way, as compared to most dynamic mics which try to keep out as much ambient noise as possible. As such, when spl is lower because the source is more distant, condensers are usually a better option. This is what literally every website, manufacturer, guide etc... says.
As such, condenser mics are usually used for things like choirs and orchestras and would seem to fit the application I am asking about.
If this is not the case, and condensers are no different then why have both types? While I'm not even remotely the follow the herd type, it seems unlikely to me that a few select handful of people know the truth and everyone else is completely wrong and uninformed.
I've already received some ideas about how not to use a condenser, so I'm wondering if anyone has suggestions on what mics other than an SM58 I might use on booms or carefully mounted on the sets so they are placed correctly that will pickup 5-8 singers as a group.
g'bye, Dick Rees
  • Duluth
« Reply #24 on: July 26, 2015, 09:45:00 pm »
I already gave you the suggestion of widening the pickup area by using a pair of 58's on a stereo bar on a single stand.  Look back and check it out.
Regarding my clarifications of Scotts posts, there is an occasional grain of truth, but often it is only part of the story and not directly applicable to your situation.  And sometimes there's just misleading topic swerve.  Such posts quibbling about mic response condenser vs dynamic clouds the issuue at hand and introduces needless confusion into a discussion of the direct application of what you have to use in your specific situation.
Again, LOUDEST SOUND AT THE MIC WINS.  No matter what the mic, you have to consider if and how it can be deployed for the desired application.  In your situation the mics you have now can be made to work just fine.  Even if you buy more or different mics, the salient factors are deployment and operational skill/experience...factors which are necessary regardless of the mics.
It's not the hammer, it's the carpenter.  You have to know what you're doing and that doesn't come in the box with the mic.
« Last Edit: July 26, 2015, 09:59:12 pm by dick rees »
g'bye, Dick Rees
  • Duluth
« Reply #25 on: July 26, 2015, 10:11:18 pm »
The highlighted section' is not strictly true.  ALL mics have patterns developed for specific applications, but NONE of them can distinguish between desired and undesired sound and ALL of them have to be deployed in a manner favorable to their functioning as desired/required.
For your specific purposes you need the voices and the mics to be as close in proximity as possible and for your sources to PROJECT so the mic (whatever you have) will have something with which to work.
There's more to it than just the method of transduction, sensitivity , pattern and such.  The question is will it work in your situation...and how well it will work.
« Last Edit: July 27, 2015, 07:28:57 am by dick rees »
« Reply #26 on: July 27, 2015, 12:15:24 am »
Condensers are more sensitive.  That is why they are so commonly used for micing up choirs ... and not so commonly used for micing guitar cabs.
I would hang something like one of these:  https://www.ccisolutions.com/StoreFront/category/choir-overhead-microphones and give it a try.  Keep in mind that the cardiod pattern will pick up a much wider area than the hyper or super will.
Sadly, I don't have much experience with the different options for these hanging microphones (not even sure which ones my church uses).  Hopefully someone else can chime in.
If you don't mind having a stand on stage, it is entirely possible to set a single SM58 at a reasonable distance from 2 singers and pick them both up.  Keep in mind that this may cause feedback issues (as might the condenser) that you don't have with the lavs since the gain will have to be higher in order to get the lower SPL picked up.
Actually, I have had quite a time with some lavs I have worked with causing feedback issues (weddings btw) where hand held mics were much better.
Dick, it isn't an urban myth that Condenser microphones are by design more suited to picking up lower SPL, but thanks for your evisceration.  I haven't had my weekly beating this week and was feeling neglected.  An SM58 isn't the solution to every vocal micing situation.  Frankly, I think they are seldom the right choice in the current competitive environment that they are in .... and really only survive at all due to the venerable past they have enjoyed.  They are tough, are better sounding than most $20 microphones, and everyone has used one so they are familiar.
Tim, I agree with most of what you said.  By "distant sources" what is generally meant is that the SPL is lower.  Condenser design is more capable of being made more sensitive than a dynamic microphone can be made (at the same cost point of course).  This is why overhead choir microphones are almost entirely condensers (I haven't looked for a dynamic one, but I am postulating that one may, in fact, exist among the ocean of condensers out there doing the same thing).
It is easier to make a small diaphragm condenser mic have better phase behavior because of lower mass of the transducer assembly compared to the moving coil of a dynamic mic.  This is why some folks love (or hate) mics like the Shure KSM9 or Neumann KMS105 - the sound sources sound natural and distinct; the hate coming from "it picks up the whole damn stage."  Guess what?  Cheaper mics do, too, but we don't identify those other sounds because they get lost in the phase-incoherent wash AT THE CAPSULE.  The nice Heil dynamics are often mistaken for condensers because they, too, have great phase response on and off axis and you can pick out the sources of much of the soundstage behind the singer or instrument.  But it's not a case of condensers automatically being "better".
As for sensitivity, what does it matter when the acoustic noise floor  (undesired signal) is equal to or greater than the desired signal?
Nathan Vanderslice
« Reply #27 on: July 27, 2015, 12:57:11 am »
How many sm 58's and channels do you have available? You're best bet is probably use 2 or 3 mics on stands and group the kids in 2 or 3 to a mic. The other thing is if you have to deal with scene changes. This needs to be done carefully to not have a potential disaster, or injury. Use the cast members/singers to help with this. If you have a way to conceal the cables on stage then just pull the cables, and grab the stands and mics as units and clear them. You're guys on mix need to be ready for this to avoid any nasty pop or other noises that can happen. If you have a good EQ on the system, you can probably get a pretty good gain on the mics without worrying about feed back as you are so far behind the speakers. The other part of this is to minimize the number of mics that are hot at once when possible. More mics hot=lower feedback threshold. Good luck. BTW, if your HS is anywhere near the MS, and you have a sound crew at the HS, perhaps you can get them interested in helping. There's a good chance that you'll get one who is eager to get mix time. Be sure to set standards for performance (mostly commitment and attendance). Remember that they are learning too.
g'bye, Dick Rees
  • Duluth
« Reply #28 on: July 27, 2015, 07:37:32 am »
Tim...
Thanks for the clarification.  i've edited my post to remove the unclear sentence.
Nathan...
Jesse has stated his problems with uneven response when grouping kids around a single 58, thus my suggestion of using a pair of 58's on a stereo bar @ around 60 degrees to use what he already has mic-wise to get the broader pickup pattern he was desiring.
As to clean stage and reducing cable clutter, my best suggestion is still to use the existing lav-carrying members as "human mic stands".
No muss, no fuss, no cables at all.
Scott Bolt
« Reply #29 on: July 27, 2015, 09:50:33 pm »
Tim,
It was my assumption, although I didn't state it, that the reasoning behind the better behaviors you describe was due to the lower mass of the transducer in a condenser mic.
You do have a point about the noise floor though.
It is still quite common for choir stages to use suspended condensers for this kind of application.
Pages: 1 2 [3] 4   Go Up
