Author Topic: Array Correction  (Read 3283 times)
Jason Raboin
    • Klondike Sound
Array Correction
« on: July 14, 2015, 03:47:13 am »
Does anyone know why Meyer removed the array correction function from the Callisto processor?
Jason Raboin
Partner
Klondike Sound
Brian Bolly
Re: Array Correction
« Reply #1 on: July 14, 2015, 07:35:36 am »
Processing resources.  Delay Integration eats up a lot of DSP horsepower, and in discussing with a large user base the majority were using TruShaping instead of Array Correction to be more precise with EQ.  You'll also notice the front end Graphic EQ went away in the Callisto (I can count on one hand the number of people I saw use that).
It is easy to recreate some of the Array Correction filters with the U-Shaping filters in Callisto, even on the fly.  I've done it before just for kicks, but I mostly found I either didn't like the filter knee or the amount of cut applied on the default Array Correction, so I ended up sculpting with TruShaping/U-Shaping as well.
Scott Helmke
« Reply #2 on: July 14, 2015, 10:15:56 am »
What happens if you load a regular Galileo preset w/ array correction into a Callisto?
Brian Bolly
« Reply #3 on: July 14, 2015, 10:52:29 am »
Anything where the control is identical between boxes (gain, names, parametric, delay, etc) will transfer.  Things that will not transfer are where there's a mismatch - TruShaping/U-Shaping, Array Correction, Delay integration, etc.
Jason Raboin
    • Klondike Sound
« Reply #4 on: July 26, 2015, 05:28:26 pm »
I've been fortunate to get to mix on some amazing PA's on this tour, from D&B J/V, L'acoustics K1/K2, to Adamson E15, and last night on Meyer Leo.  The Leo rig last night was the only one that left me unsatisfied.  It was 14 per side at the Paleo festival in Switzerland.  I had very little time to tune, and no sound check.  My measurement put it at around plus 9 in the low end and minus 3 by 4k, minus 6 at 8k.  The system was being controlled by 3 Calisto's which I was not granted access to.  There was a Lake I could use, but there was no tablet, the control cpu was located 10' from me, and I had to turn my back to the stage to use it.
With array correction I could have asked them to set it at 7 and know I would at least be in the ballpark.  But I was apprehensive to try to replicate this on a Lake.  First of all I couldn't believe that a system at a festival this large would be tuned that way.  And second because the tuning often needs to change once the crowd shows up and the show starts.  The way this one was set up I would have missed mix cues by going over to where the Lake control computer was.
The day on the E15 rig - 24 per side at Vielle Charrues, the largest festival in France, didn't start out sounding good, but got there in the end.  Again the system tech hadn't done any array correction so there was a massive low end buildup.  This worked well during the soundcheck for David Guetta, but not so well for me, mixing a folk act at 85db.  After line check someone from Adamson asked if he could interview me on camera for their website.  I was not in a good mood and told him that I would not make for a good interview currently because I thought their PA sounded like shit.  A couple of hours later he came and found me and told me that there was an option to use an array correction filter in their Lake processing, but the system tech had opted not to because the largest array size was something like 16 boxes, and we had 24.  He apologized and said he would help me get where I needed to go during changeover.  He did just that and it was a pretty good show.  I wouldn't put it up there with L'acoustics or D&B, but pretty close.
It seems that I keep finding new lines in the sand - new features that separate the best from the rest.  A few years ago it was the use of FIR filters.  Now it seems to be the simple and repeatable array correction function in a manufacturers processing.  L'acoustics LA Network Manager is the hands down easiest way to get a PA tuned quickly.  Between the array morphing, the FIR filters for the high end, and the IIR filters for the low end, you really don't need anything else.  D&B, with CPL and air loss compensation can also get you there very quickly.  Nothing else I have used can get you there fast or as phase coherently.
Jason Raboin
Partner
Klondike Sound
Scott Helmke
« Reply #5 on: July 26, 2015, 05:40:56 pm »
Meyer did away with the array correction in the Callisto processor, though. There is expanded other EQ available, so the rationale is that since you'd be doing a proper measurement job anyways you can do the correction "from scratch".
I don't really agree with that tradeoff.
Page created in 0.082 seconds with 24 queries.
