Author Topic: Convert HID Instrument to Halogen  (Read 1246 times)
BrianMiller
    • Online Design Portfolio
« on: June 25, 2015, 05:37:37 pm »
I have found some used Source4 Jr ellipsoidals for a terrific price that are outfitted with HID lamps. I would like to convert them back to halogen, and was wondering if anyone has experience doing this sort of thing. I am assuming I will need to replace at least parts of the lamp housing. Are there more drastic things I need to keep in mind, or look out for?
Tom Bourke
    • http://www.cwalv.com
Re: Convert HID Instrument to Halogen
« Reply #1 on: June 25, 2015, 09:16:27 pm »
Give ETC a call.  They have some of the best tech support I have ever worked with. https://www.etcconnect.com/Contact/Americas.aspx
Jeff Baumgartner
« Reply #2 on: June 26, 2015, 03:04:15 pm »
All you have to do is change the cap. Done it before on Altmans. ETC should be the same.
BrianMiller
« Reply #3 on: July 03, 2015, 04:17:17 pm »
Thank you gentlemen, for your responses. I did talk to ETC, and in the end, I have decided to keep them as HIDs, and will control them with Elation Uni-pac dimmers set as switches (hopefully will be able to wire the two instruments together, so I only need one). They will be lighting a large cross suspended close to twenty feet off the ground in a church sanctuary. I came to the conclusion that if anything in the place needed constant illumination, it was that. :)
Page created in 0.059 seconds with 22 queries.
