Pages: [1] 2 3 ... 6   Go Down
Author Topic: Sparky Language Lesson  (Read 11052 times)
Timothy J. Trace
« on: June 25, 2015, 01:54:42 pm »
Coming from a guy with my mileage...sheesh.
How do I clearly, and concisely, ask an electrician for lugs to tie in my two 50A legs of 110VAC single-phase on a common, bonded neutral and ground?
I typically say, "50A single-phase, please." Industry sparkies immediately grok my needs, yet I often confuse uninitiated commercial electricians.
I'm hoping for a lesson today in how to more clearly express my desires to a wider audience.
Thanks.
« Last Edit: June 25, 2015, 02:28:32 pm by Timothy J. Trace »
Post count...whaaaaa? I ain't no newb. Search for my name in the LAB Archives.  :)
Mark Cadwallader
  • Helena, Montana USA
Re: Sparky Language Lesson
« Reply #1 on: June 25, 2015, 02:33:45 pm »
May I respectfully suggest that this question should be moved or reposted in the AC Power sub-forum?  Lots of sparky-types over there.
Andrew Broughton
    • Check Check One Two
« Reply #2 on: June 25, 2015, 02:44:26 pm »
I would say:
"50A single-phase 4-wire".
If you don't say 4-wire, the electrician doesn't know that you want 2 hots instead of 1.
-Andy
Timothy J. Trace
« Reply #3 on: June 25, 2015, 03:47:53 pm »
Mods, please.
« Reply #4 on: June 25, 2015, 04:00:18 pm »
I would say:
50 amp 120/240v single phase with ground (3 wires plus ground, 4 wires total).
I've found that non-entertainment electricians do not consider the EGC to be "a wire".  The 120/240v designation SHOULD tell the electrician that we want split-phase, not 240v service.
When specifying 3 phase power I've found it necessary to call out WYE service, as in "200 amp 120/208v 3 phase wye, 4 wires plus ground (5 wires total)."
Timothy J. Trace
« Reply #5 on: June 25, 2015, 04:44:47 pm »
That's quite helpful, Tim. Thank you. Two follow-on q's which I know will be a cakewalk for you LOL ---
  • How does this sound? "50A split-phase 110V phase-to-neutral, 3 wires plus ground, 4 wires total, for connecting a tail set or an L5-50P."  ....or did I get too wordy?
  • Forgive my ignorance, must the two hot conductors always be fed from separate lines of the split-phase, or may they draw from the same phase if the individual upstream breakers equal each conductor's ampacity?
« Last Edit: June 25, 2015, 04:46:56 pm by Timothy J. Trace »
Mark Cadwallader
« Reply #6 on: June 25, 2015, 05:17:26 pm »
Perhaps you made a typo, but an L5-50P is for one 125v leg, not two. The NEMA designation for two legs (125/250 v) is 14-(amps).  I have seen 14-50p (straight blade range plug), but never an actual L14-50p. There is a 125/250 3 pole, 4 wire device, but it is the "CS" (California standard) series. (Namely the CS 6365.). The L15-50p is for 3 phase,250 volts only.
Andrew Broughton
« Reply #7 on: June 25, 2015, 05:18:02 pm »
I think you would need a double-sized neutral for that to be legal.
-Andy
Timothy J. Trace
« Reply #8 on: June 25, 2015, 05:40:52 pm »
Perhaps you made a typo...there is a 125/250 3 pole, 4 wire device, but it is the...CS 6365.
Thanks much, Mark. You're being generous by calling it a typo :)  I was outright mistaken.
These are functionally similar to my cables: http://www.motionlabs.com/pm-240-1-64-50a-125250v.aspx .
Is this better? "50A split-phase 110V phase-to-neutral, 3 wires plus ground, 4 wires total, for connecting a tail set or a CS6365C." I want to be concise as possible, so if I'm saying too much, please let me know.
« Last Edit: June 25, 2015, 05:44:46 pm by Timothy J. Trace »
Timothy J. Trace
« Reply #9 on: June 25, 2015, 05:42:23 pm »
Thanks. Can you help me understand how this is different than having two branch circuits drawing off the same line? Is it because we're dealing with portable distribution?
Pages: [1] 2 3 ... 6   Go Up
Page created in 0.027 seconds with 22 queries.
