Author Topic: SDI to HDMI splitter  (Read 3127 times)
Tamar Ghobria
« on: June 22, 2015, 02:23:13 pm »
Is there any device out there that will take a SDI input and split to 4 or more HDMI outputs? Using a Roland VR-50 and need to send signal to 4 monitors around the room
John Rutirasiri
Re: SDI to HDMI splitter
« Reply #1 on: June 22, 2015, 11:51:55 pm »
Not that I know of.  How about:
1) SDI from VR50HD to SDI->HDMI converter located at 1st monitor, loop out to the next monitor, etc.
2) HDMI out from VR50HD into HDMI splitter (with EDID management of course)?
John R.
Sound/Lighting/Corporate A/V
Jordan Wolf
« Reply #2 on: June 23, 2015, 12:04:56 am »
Tamar, your best bet will be to distribute using SDI and convert on the monitor end. Both Black Magic and AJA make boxes that convert  SDI to HDMI; try Rentex for subrental.
Jordan Wolf
Tamar Ghobria
« Reply #3 on: June 23, 2015, 09:19:26 am »
John R.
I don't believe there is a video output on the monitor...the challenge is even with a hdmi splitter the other monitors are so far away I would have to use multiple adaptors....Does anyone know if the aux video out on the vr-50 will mirror the pgm ouput?
Milt Hathaway
    • http://www.fitzcosound.com
« Reply #4 on: June 23, 2015, 10:17:57 am »
Every SDI to HDMI converter (actually every SDI converter) I've ever seen had a loop-through for the SDI signal. The better ones reclock the signal before looping it so you don't get additive deterioration of the SDI signal.
SDI distribution modules are very easy to find also, if that suits your wiring situation better. You'll find that SDI is much cheaper to run and distribute than HDMI, especially over long distances.
Regarding the VR-50: Yes, you can assign the main video mix to the aux out connectors (and vice versa should you ever need it).
Milt
FitzCo Sound, Inc.
Midland, TX
Tom Bourke
    • http://www.cwalv.com
« Reply #5 on: June 23, 2015, 10:40:23 am »
We have had bad luck with the loop out on most converters.  Signal degradation caused drop-outs after about 3 converters.  We found it much better to hit a DA and then home run every TV or pair of TV's.  Keep in mind every reclock adds delay.  It can gets noticeable on large systems.
Cailen Waddell
« Reply #6 on: June 23, 2015, 11:03:28 am »
All things considered look at monoprice for sdi to hdmi converters.  They are reliable and cheap enough to almost be disposable.    We use black magic in places where reliability is critical but a side stage monitor or dressing room monitor isn't such a big deal
Tom Bourke
« Reply #7 on: June 23, 2015, 04:14:04 pm »
Lately I have been having much better luck with the low price throw away units than Black Magic.  The Black Magic firmware and control software has been a real PITA.  The software does not unistall properly for an upgrade and you end up with a strange merge of the two versions.  We have also had problems with the handling of some color space, refresh rates and resolutions.  Tech support told me it can't be their unit, every thing else must be wrong :o.
Any way, when I go to the closet for a converter, the Black Magic's are the last ones I will grab if possible.
Page created in 0.047 seconds with 24 queries.
