Pages: 1 ... 3 4 [5] 6   Go Down
Author Topic: Honda EU3000iS gennys in parallel  (Read 29208 times)
Steve M Smith
  • Isle of Wight - England
Re: Honda EU3000iS gennys in parallel
« Reply #40 on: June 22, 2015, 10:56:07 AM »
Are these electrical inspections common in the US?  Over here we just plug in and go.  I don't think I have ever seen an official of any type looking at the electrics.
Steve.
Frank DeWitt
    • LBP DI Box
« Reply #41 on: June 22, 2015, 12:27:54 PM »
Sort of like putting out cookies and milk for Santa... 8)
I attended a seminar for worship teams at a mega church.  It ran all day and in the evening there was a concert.  The techs among us received a tour of the "booth"  (About 5 rooms) and were told we could come up any time except during the concert.  Our small church group had dinner delivered and received the dozen cookies we ordered plus two dozen extra.  It was more then we could eat so I took them up to the door to the booth.  the guy unlocked the door and I gave him the cookies explaining they were leftovers, and turned to leave.
Aren't you cumming in?
I thought we weren't allowed during the concert.
You brought cookies.
I enjoyed watching the camera and audio mixing.
Not to Code
frank kayser
« Reply #42 on: June 22, 2015, 10:46:54 PM »
... but honest, boss!  He brought cookies;D
Steve Alves
  • South Florida
    • South Florida Sound
« Reply #43 on: June 06, 2016, 10:38:58 AM »
Need to resurrect an old thread. Looks like this would be the best place to ask. I have two of the 3000is generators. I normally use one with about a 22 amp load using the 30 amp connector. Of course you don't really get 30 amps out of it and every once in awhile it cuts off due to a short term overload (guessing around 26 amps).
As previously discussed Honda no longer makes a parallel kit for these....... BUT......
I found this, looks like it would work.. Any thoughts?
http://www.northerntool.com/shop/tools/product_200660537_200660537
Steven Alves
South Florida Sound, Fort Lauderdale, FL
www.southfloridasound.com
Mike Sokol
« Reply #44 on: June 06, 2016, 01:47:08 PM »
That appears to be a NEMA 5-50R receptacle rated for 50 amps and 125 volts, correct? If so, and if the "banana plugs" will fit into the Honda generator, then this should work.
Mike Sokol
mike@noshockzone.org
www.NoShockZone.org
Jonathan Johnson
« Reply #45 on: June 06, 2016, 02:36:49 PM »
Standard disclaimer: this may void the warranty of your Honda generator as it is not a Honda-supplied product. It may also violate some AHJ's sense of prudence.
Side note to standard disclaimers: the term unsupported does not necessarily mean does not work or unsafe. Use good judgment.
Mike Sokol
« Reply #46 on: June 06, 2016, 07:46:13 PM »
Honda does make a parallel kit for the 3K Handi, but won't rate it for the EU3000iS. When I talked to their marketing guys about this, there was something about drawing continuous loads through those little banana plugs. While that might be an issue for lighting, it's probably not an issue for sound due to the crest factor. I've already emailed the manufacturer's tech support about getting a unit to test, but who knows if they'll send one.
Mike Sokol
www.NoShockZone.org
Steve Alves
  • South Florida
« Reply #47 on: June 06, 2016, 10:29:17 PM »
So I understand correctly, looking at outlet, left blade common, right blade hot, ground on bottom???
As opposed to two hots and one ground right? When I think of a 50amp connector I see it as 240 volt.
Steven Alves
Mike Sokol
« Reply #48 on: June 07, 2016, 12:42:35 AM »
That's correct. Don't assume that any receptacle that's big is 240 volts. If you look closely you'll see that there's 125 volts max printed on the face of the receptacle.
« Last Edit: June 07, 2016, 12:52:28 AM by Mike Sokol »
Mike Sokol
www.NoShockZone.org
Steve Alves
  • South Florida
« Reply #49 on: June 07, 2016, 11:58:44 PM »
One more question, the wires on the kit are color coded red & black (plus green ground) and the banana outlets on the generator it is actually sold for are also color coded...
But, my Honda's have no color code.. Guessing it matters.. May have to meter before making connections.
Anyone know?
Steven Alves
Pages: 1 ... 3 4 [5] 6   Go Up
Page created in 0.082 seconds with 20 queries.
