Author Topic: Combo cinema and PA sound system  (Read 4630 times)
Timmy Liland
« on: June 14, 2015, 04:55:30 pm »
I have some questions regarding an installation that will be finished in 2017.
There will be cinema, brass bands, amplified acoustic instruments, rock nīroll and theater performances on this stage.
The audience area is 17m wide and 15m deep. (Back wall to speaker hang)
Ceiling height is 10m.
There are around 350 seats in 13 rows, the back row is 4m above floor level.
The front row is around 2m from the speaker hang.
Does anyone have experience with installed loudspeaker systems that can be used for both cinema and normal PA duty? (There will be aditional senter and surround speakers.)
What is most suitable in this room, line array or point source?
Doug Fowler
  • Saint Louis, MO USA
Re: Combo cinema and PA sound system
« Reply #1 on: June 15, 2015, 03:41:11 pm »
Point Source.
Budget?
Don't get cinema speakers, get PA speakers.
Cailen Waddell
« Reply #2 on: June 15, 2015, 04:19:39 pm »
We have a 200 seat theater that does live music and cinema with a 7.1 system.
The system is danley sound labs speakers
Briefly
SM-100b for left right and center
Sh-micro for all surrounds
Th-112x2 subs under front of stage. Our sub choice may of been different with different space options.
Console is a Yamaha cl3 fed by a surround decoder.  Each channel is fed discretely through the console.
Biamp audia to do processing and alignment.
The screen is retractable with the L/C/R above the screen.  Imaging works fine. Given an AT screen and seperate speakers wasn't an option.
The room is very dry, purposefully, for movies.  The surrounds being accessible from the console are also helpful as we sometimes put a little reverb on the whole PA and rout the return to the surrounds with the right kind of act.  If done discretely it can give a little sense of space to the hall.
I always prefer a point source in an installation. Line arrays just don't do it for me
Timmy Liland
« Reply #3 on: June 15, 2015, 04:34:24 pm »
Point Source.
Budget?
Budget is around USD 100000 for ALL the sound equipment.
(PA, monitors, mixer, mikes, kables, etc)
Unfortunately, due to the bidding process we canīt get better quality second hand equipment. This also means that we canīt buy what we want.
« Last Edit: June 15, 2015, 04:44:23 pm by Timmy Liland »
John L Nobile
« Reply #4 on: June 15, 2015, 04:55:36 pm »
Our room has a live show and we show movies in it as well. It;s a resort so we play family movies and sports events. A pair of Danley SH96HO's and a pair of SBH218's and I gotta say that it's the best movie/live sound I've ever heard in that room. It's only run in stereo but it works for me.
Room is 72' wide and either 75' or 105' deep with 16' ceiling.
Scott Carneval
    • Cenero Audio Visual
« Reply #5 on: June 15, 2015, 05:43:18 pm »
Briefly
Cailen gave me a demo a while back and the room sounds truly incredible.
Glen Kelley
  • El Paso, TX
    • The University of Texas at El Paso
« Reply #6 on: June 30, 2015, 11:14:29 am »
Cailen, if you don't mind me asking, what surround decoder are you using? Is there a control system for day-to-day use, or do you always have a tech available?
Cailen Waddell
« Reply #7 on: June 30, 2015, 11:37:13 am »
We have a extron ssp 7.1
We are changing to a denon 500av so we can decode from the hdmi audio and get higher quality audio.
We have a crestron control system but I did not get it programmed so it can be operated without a technician.  I feel there are too many variables in play for that to be reliable.  Especially considering the number of old movies with potentially odd formats...  Dolby 3.0?  Ok. Should i route to subs?  That sort of stuff.
The crestron does some input switching and routing to lobby monitors, backstage monitors, etc.  Remote projector control, etc.
If I wanted operation without a tech I think we would of looked into an integrated theater control/audio/projection package that can adjust screen masking and dim lights, etc.
If I wanted to go the route with
Glen Kelley
  • El Paso, TX
« Reply #8 on: July 09, 2015, 11:08:29 am »
Thanks, Cailen. I have the Denon 500av in our student union cinema, and we are putting the Extron in a new student housing project, but both have drawbacks. Was hoping you had found a magic bullet! It seems there are either "pro-sumer" home theater options, or full on pro solutions that are super-pricey.
Cailen Waddell
« Reply #9 on: July 09, 2015, 11:09:55 am »
The extron certainly has extra processing power, with EQ and delay, but it isn't something we used.  Be aware with that box you can NOT get an full 7.1 signal.  It will always be a 5.1 with the box matrixing the extra rear surrounds.
ÂŦ Reply #9 on: July 09, 2015, 11:09:55 am Âŧ
