Pages: 1 2 [3]   Go Down
Author Topic: Hardware controlled Dante Patching  (Read 6284 times)
Robert Lofgren
Re: Hardware controlled Dante Patching
« Reply #20 on: June 15, 2015, 02:38:41 am »
Robert seems to think it would work...
Here it is explained in more detail how it is supposed to be setup and work:
http://dev.audinate.com/GA/dante-controller/userguide/webhelp/#device_names_and_channel_labels.htm
However, murphy's law is always around...
As for switchover time it should be "within just a few seconds":
http://dev.audinate.com/GA/dante-controller/userguide/webhelp/#discovery_and_auto-configuration.htm
« Last Edit: June 15, 2015, 02:50:05 am by Robert Lofgren »
kristianjohnsen
  • Lillehammer, Norway
    • Lillehammer Lyd og Lys
« Reply #21 on: June 15, 2015, 05:56:28 am »
I built a playback system that uses 2 computers outputting audio simultaneously into a Radial SW8 switcher so if there's a problem with one computer, I can flip a switch to go to the backup computer almost instantly.
Since the rig they run into is now using Dante, I would love to do away with the soundcard and interface, SW8, preamps, etc. and have the computers output their signal using DVS directly.
Obviously in the case of a failure, I could switch outputs using Dante Controller, but that would be too slow and problematic, even if I was using a preset, and it needs to be able to be switched by anyone, ideally using a hardware switch like before. Can a Dante Controller preset be recalled somehow with a hardware switch?
Is there another way to do this? I guess the switching could be done at the consoles, but again, it needs to be a simple remote switch that can be actuated by anyone.
Suggestions?
Just thinking out loud here.
There are Dante-enabelled products with headphones outputs and possibilities for listening to one stereo stream at a time.  The new and very cool Appsys "Dante->many formats"-bridge comes to mind.
Any chance the two computers could be routed via a router through a unit like the Appsys bridge with one computer being ch 1+2 and the second being ch 3+4, then someone could just arrow one up/down and hit enter to route the alternative source to the headphones output, and then that could be used as the audio output?
kristianjohnsen
« Reply #22 on: June 15, 2015, 05:58:22 am »
Yeah, that's what I'm starting to think as well. Now, with a FOH and MON console both needing to be remotely switched at the same time, that's a bigger trick. If I were able to use control signals down the Dante line (the way the CL/QL does with communication between Nuendo Live and the console) that would be a slick solution without the need for extra GPIO lines running to FOH.
MIDI-> ethernet-boxes running on the redundant network of the audio gear?  We all know you are the MIDI-Gandalf around here:)
David Sturzenbecher
  • So. Dak.
    • Sturz Audio
« Reply #23 on: June 15, 2015, 07:27:24 am »
I think you mean MADI
« Last Edit: June 15, 2015, 09:07:35 pm by David Sturzenbecher »
Audio Systems Design Engineer
Daktronics, Inc.
CTS-D, CTS-I
AES Full Member
kristianjohnsen
« Reply #24 on: June 15, 2015, 08:41:44 am »
I meant that if he wants to trigger stuff on a remote console, but doesn't want to run GPIO-cables, perhaps he could set up a device to trigger the same events via MIDI.
Considering the console is already part of a network (two actually, counting redundant), the network could be used to get the MIDI-commands from a remote controller to where the console is, by using a MIDI->ethernet / ethernet-MIDI extender system and just "piggybacking" it's data traffic on one of the networks.
Chris Johnson [UK]
« Reply #25 on: June 15, 2015, 11:20:12 am »
I
IP MIDI would work fine. Kissbox make a nice I/O box
Riedel Communications
Andrew Broughton
    • Check Check One Two
« Reply #26 on: June 15, 2015, 11:35:15 am »
It's already built-in, just not documented.
« Last Edit: June 15, 2015, 11:46:17 am by Andrew Broughton »
-Andy
brian maddox
  • HeyYahWon! ttsss! ttsss!
« Reply #27 on: June 15, 2015, 03:13:13 pm »
IP MIDI is built in to the console?  Which console?  If it's a CL5, that would solve an issue for me....
Or did i misunderstand?
brian maddox
bdmaudio@gmail.com
Andrew Broughton
« Reply #28 on: June 15, 2015, 03:36:21 pm »
Not IP MIDI, but MIDI communication via LAN (in their own format) is done for the CL/QL Editor communication.
A similar system is used for the CL/QL communication with Nuendo Live, but through the Dante connection instead of the Editor connection.
I'm doing work with both systems currently. Contact me via my web site if you'd like to discuss in more detail.
-Andy
Pages: 1 2 [3]   Go Up
Page created in 0.043 seconds with 23 queries.
