I'm going to acquire an X32 Rack and wondered what the folks who are already using one are using for a case.
Anyone using an SKB 1SKB-R3S? (SKB's shallow 3RU roto-molded model with front and back lids) It looks like it would be a great fit, but I'm a tiny bit concerned about the depth between the front and back rails compared to the depth of the mixer, which is .6" deeper. How about the handles on the front of the X32 (which I assume are removable)? Are you using something else that works well?
Thanks for your insight!
Since these were taken, I have gone to an 8 space SKB roller rack. I am actually wishing I would have gone with the 6 space instead though since it would be smaller and somewhat lighter.
As you can see from the picture below, I used to use a wood case. Here was the issue.... it was darned heavy. The point of going with the X32 Rack was to make things smaller and lighter. The rack was heavier than everything inside it .... so it is gathering dust in my basement storage now
I also thought about getting a rack that was JUST big enough for the X32 Rack; however, I have my IEM send, 8 channel DI, and power strip that all need to be permanently wired into the case. 6 spaces would be perfect for this.
As you can see, I also have an LED light in the back of my rack. This is very cool for hook up and tear down since I can't forget to bring the flash light
I have been considering making a patch panel on the back of my current rack as well. That way I wouldn't need to reach into the back to plug in the XLR's. It isn't bad, but it could be made better. Since my band is generally what gets hooked up, I could also use the patch panel to label the inputs on the back so even my band members .... who can't seem to remember where their mics and instruments plug in no matter how many times I tell them .... could plug in without bothering me during setup.
Finally, I have a color coded vDrum snake that goes into the DI. I have tapped this to the top of the DI for both the vDrum side and the DI side so that my Drummer can plug in his own equipment.
In a pinch, we can setup the entire PA (without lighting) in 30 minutes. With my old passive speakers and analog mixer rig, I used to leave 2 hours for setup.
