Author Topic: lynx-technik yellobrik sdi over multi mode fiber?  (Read 1092 times)
Tom Bourke
    • http://www.cwalv.com
« on: April 29, 2015, 01:14:00 am »
Any one used them? http://www.lynx-technik.com/en/products/yellobrik/
Specifically our older convention space has multimode fiber and we need to push around HD-SDI.  Typical resolution is 720p or 1080i @ 60.  Fiber runs will be around 1000ft with a couple of com room hops.
A prime example of our use would be sending the main projector feeds from the general session one way to a smaller VIP break out room in another part of the conventions space.
Our current solution involves renting an SDI over IP set and using the Vlan setup.  I would be using the spare fiber links from the same system.
Page created in 0.036 seconds with 22 queries.
