Author Topic: Blowing fuses - does this make sense?  (Read 3988 times)
Jerome Malsack
Re: Blowing fuses - does this make sense?
« Reply #10 on: April 29, 2015, 10:56:03 am »
Yes but also consider the second one on the chain because if you move from 5 on on and 3 on the others, you may need to do 4 on the second on in the chain because it has two others added to it.
Steve M Smith
  • Isle of Wight - England
« Reply #11 on: April 29, 2015, 11:35:27 am »
I would put a 5A fuse in all of them*  If there is a problem, it will blow.
* Note - that is what I would do and should not be taken as advice!!
Steve.
Debbie Dunkley
  • Central North Carolina
« Reply #12 on: April 29, 2015, 12:06:33 pm »
Yes that is what I meant- replace the fuses to 5amp in ALL the fixtures linked together. However, at this point I'll just link them in pairs on the 3 amp fuses till I get around to grabbing some 5 amp fuses.
Debbie Dunkley
« Reply #13 on: April 29, 2015, 02:20:00 pm »
One last thing- a shout out to Bruce at Blizzard for getting back to me so quickly and explaining what my problem was. Tried getting help with Chauvet a couple of times a few years back and I'll just say the end  result wasn't as successful.
duane massey
« Reply #14 on: April 30, 2015, 12:23:31 am »
Makes perfect sense, but I am surprised they link the power through the fuses. I'll have to check some other brands to see if this is common practice.
Duane Massey
Houston, Texas
Mark Cadwallader
  • Helena, Montana USA
« Reply #15 on: April 30, 2015, 12:39:46 am »
The Blizzard user manuals I have looked at include a specification as to the number of identical fixtures that can be "daisy chained" at 120 volts, 208 volts, and 240 volts AC mains.  IIRC, it varies by model.
Jeff Carter
  • Kitchener, ON, Canada
« Reply #16 on: April 30, 2015, 10:44:40 am »
They probably can't make any assumptions about fuse/breaker protection of anything connected downstream, so if the link's not protected with a fuse I think it would need to be able to handle the 15A necessary to trip the circuit breaker upstream.
Mothers, don't let your babies grow up to be physics PhDs
Page created in 0.056 seconds with 23 queries.
