Author Topic: SPL td-1 limiter settings  (Read 4839 times)
Ara Ayrassian
« on: April 28, 2015, 01:31:32 PM »
Anyone have any limiter settings for the td-1's? Thanks
Danley SH96HO's 2 DBH218 powered ,SPL td-1's  Danley DSL P48 processor 2 x Danley THmini 15 subs 4 SM100's 2 SH50's and Ashly Protea 4.24C ,Crown tech 6000, Crown MA12000i QSC PLX 3602 , Crown xdi 6002, EAW JF80 x 4 Altec A6 VOTT, EVZXA1's
You can be right with a wrong spirit so listen carefully.
Re: SPL td-1 limiter settings
« Reply #1 on: April 28, 2015, 05:27:08 PM »
I seem to recall they were rated at 400 watts @ 4 ohm continuous.
I would start there.
Ara Ayrassian
« Reply #2 on: April 29, 2015, 09:14:27 PM »
Not sure if they are 4 or 8 ohm the SPL website is no longer there with the spec sheet I'm also running 2 per side from 100Hz up ?
« Reply #3 on: April 30, 2015, 07:56:29 AM »
I am pretty sure they were 4 ohm.  I installed quite a few of them, and always passive.
Ara Ayrassian
« Reply #4 on: April 30, 2015, 04:20:40 PM »
John H was kind enough to send this
Frequency Response
65 Hz-20kHz 3dB (2 or more boxes)
Sensitivity   103 dB @ 2.8v/1m
Power Handling   600 Watts Continuous
Peak SPL   137dB @ 800 Watts Pink Noise (6dB Crest Factor)
Nominal Impedance   8 Ohms Average
Coverage Pattern   60V x 40H
Transducers LF   2 x 12"
Transducers MF   4 x 5"
Transducer HF   1 x 1"
Weight   130 lbs.
Dimensions   29"H x 23"D x 19"W
Construction   13 Ply Baltic Birch
Finish
Black Catalyzed Texture Coat,
White Catalyzed Texture Coat
Line-X Exterior Coating
Box Angle   30 Degree Trapezoid
Connectors   2 x NL4 (Passive)
2 x NL4 & 2 x NL8 w/pin swap switch (Active)
all rights reserved, Sound Physics Labs, Inc. - 2008
« Reply #5 on: April 30, 2015, 05:18:23 PM »
Frequency Response
Weight   130 lbs.
Finish
I guess I was wrong-it has been more than a decade since I used them-Has it been THAT long??????
Ara Ayrassian
« Reply #6 on: April 30, 2015, 05:48:24 PM »
Yes funny how fast time fly's by when your having fun. 8)
Page created in 0.062 seconds with 20 queries.
