need help with what level most cell phone headphone outs are and what to use to hook to console or standard line ins. Seems like with the cell output low and the system high vs the other way around has no difference. Possible RDL solution or what.
Thanks
How long is the run?
I just make my own cables, a 1/8" to a pair of XLRs, wired pin 2 hot, pin 3 gnd.
It works great.
If you need a mono connection, then put a series resistor (a couple hundred ohms or so) for each channel and then parallel them.
Again pin 2 hot, pin 3 ground.
I leave pin 1 floating in both cases.
