Hi Nimrod,
Still enjoying the use of the BT-12 from the original production run. Still nothing like it.
I know the question will come up, so we may as well deal with it now:
Can the cab lock be retrofit to the original BT12? I'm guessing the lock is not a separate apparatus, but "designed in".
frank
Hi Frank,
I'm glad to hear that your BT-12's are serving you well.
Unfortunately the cab lock can not be (easily...) retrofitted to the previous version of the BT-12. The lock design involves some holes and a weld that are done to the top stem at the pre-assembly stage. I guess this could be managed by a skilled metal worker or DIY'er but it isn't a simple task for the everyday user...
When I first started thinking and designing the lock, I did try to make it also retrofitable to the previous version of the BT-12. but it was too complicated, compromising and time consuming so I let go of the idea and aimed the design for new units only.
