Author Topic: What actually comes out of the "coax" output of a Blue Ray player?  (Read 9239 times)
Hayden's post is very accurate to clarify the stereo output encodes Dolby Pro Logic which uses matrix encoding.   If you have a high end Preamp or RX HDMI with original encoding is way to go.  If you have an Oppo or similar high end player I have found the analog outs sound better that the multichannel PCM.
Sander Rooijens
Re: What actually comes out of the "coax" output of a Blue Ray player?
« Reply #11 on: April 20, 2015, 05:26:46 am »
TOSLINK is a 2 channel optical digital format using visible red light over generally plastic fiber developed by Toshiba. ADAT is an 8 channel format developed by Alesis for their 8 track digital tape recorders using the same hardware.
AFAIK this is incorrect. Toslink describes a standardized optical fiber connection system, in other words the optical cable and connectors. It does NOT describe the type of signal.
We can have optical S/PDIF which is a 2 channel optical digital format, typically using Toslink.
or we can have ADAT which is an 8 channel optical digital format, ALSO typically using Toslink.
Different signals but both using the same cable/connection system.
S.R.
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
S.R.
Perhaps an analogy would be a single channel DMX over a data XLR or two channel AES over the same data XLR.
Page created in 0.077 seconds with 24 queries.
