Author Topic: Where to put a GEQ on an M7CL  (Read 1492 times)
James Garrett
« on: April 03, 2015, 04:10:29 pm »
I have a group of area mics on a stage and I need to ring them. Normally I would put them all into a group and insert a GEQ. The Yamaha M7 does not have groups. I ended up putting the mics into a pair of mix busses and through a pair of GEQ's and then returned them into a couple channels of the console and routed accordingly. Is there a better way?
Thanks!
  • Old enough to know better
  • Audio Plumber
Re: Where to put a GEQ on an M7CL
« Reply #1 on: April 03, 2015, 04:48:14 pm »
Thanks!
Of course it has groups. It has 16 "Mixes" that can be either variable, making them an aux send, or fixed, making them a group. You get to decide how many of each kind of mix bus you need. You set them to either type in pairs in the mixer setup menu.
g'bye, Dick Rees
  • Duluth
« Reply #2 on: April 03, 2015, 04:54:19 pm »
I have a group of area mics on a stage and I need to ring them. Normally I would put them all into a group and insert a GEQ...... Is there a better way?
Thanks!
Yes.  Use PEQ per mic, then if you must use further group processing, use PEQ.  Using GEQ on a group to gain headroom (which is what I imagine you're aiming for) is a bit heavy-handed.
James Garrett
« Reply #3 on: April 03, 2015, 05:06:07 pm »
How would I route the fixed group to the stereo bus without returning it into a pair of channels on the console?
  • Audio Plumber
« Reply #4 on: April 03, 2015, 05:29:37 pm »
By going to the master for that mix and assigning it to the stereo bus, just like you would on any console.
Page created in 0.053 seconds with 22 queries.
