Author Topic: O1v96 advice - GEAR UPDATE 14/04/2016  (Read 4241 times)
TimHackford
« on: March 26, 2015, 10:40:55 am »
Hi Everyone this is my first post tho I've been lurking here for about a week or so now and have already learnt so much so thank you, I would say I would love to be able to contribute here and give back what I've learnt but I don't know anywhere near as much as you guys but will continue to learn! Apologies for any un-technical terms I use..I am still learning.
Ok so down to business, I run the live sound for my live function band we use two tops and two subs..all the members are on IEM's so no monitors. We have been using for the last 2 and a half years the original 1998 Yamaha O1v, while I don't think its a bad mixer its very limited on capabilities so have long been due an upgrade. I was offered a O1v96v1 locally for quite cheap (£450) and as I thought I was familiar with the way Yamaha digital mixers work I brought it. I was hoping it would have more eq possibilities as I have read on here that some guys manage to get by without the need for a Graphic EQ and I tried running the speakers straight into the desk without our GEQ and the sound was so clear and refined I couldn't really believe the diifferenc I am sure we could get by without it..but by the time I have pulled out the 3-4 bands of feedback on the main vocal mics and the 2-3 bands of feedback from the guitars I am left with little to no eq control over the cutting and boosting of the vocals and guitars to make it sound how we want it. So is there a special trick anyone uses to get round this problem or something I can do to get more gain before feedback or even more bands over their peq a few more filters etc?, Im still not completely to grips with all the routing but I'm getting there its a completely different animal compared to the O1V we were using.
Thanks for any help you can give me
Tim
« Last Edit: April 14, 2016, 05:37:12 pm by TimHackford »
TJ (Tom) Cornish
  • St. Paul, MN
Re: O1v96 advice
« Reply #1 on: March 26, 2015, 10:53:15 am »
Tim
The 01v96 is no small upgrade over the original 01v.  I have two 01v96 boards.  Typically you will still use a DSP system processor after the main outs of the board, and there you can do your speaker refining.  Failing that, use the EQ on the LR mains to get close.
Channel EQs of the 01v96 are like any other board, and actually are pretty generous compared to the analog world.  If you need more EQ than that, you're doing something wrong somewhere.  The temptation with visual EQ is to make super narrow cuts, which often aren't the best choice.  Try widening the EQ bands when you make your changes and you'll likely be better off.
If you still need more EQ (and you shouldn't), you can run your channels into groups and get more EQ bands there.
TimHackford
Re: O1v96 advice
« Reply #2 on: March 26, 2015, 01:10:45 pm »
Thank you very much for the informative reply, no i realise the o1v96 is nothing like the o1v but I am really enjoying it the sound quality difference is just wonderful. I understand what you mean about the temptation with visual eq is to make narrow cuts, I also watched a few online videos sweeping about feedback and using digital desks and PEQ's they also used narrow cuts but I think thats where I am going wrong and will try widening the bands! I will also try fine tuning with the DSP, just found Ivan Beavers o1v96 manual that makes much more sense to me then the Yamaha one.
Thanks again
Tim
Jay Barracato
  • Solomons, MD
Re: O1v96 advice
« Reply #3 on: March 26, 2015, 01:59:17 pm »
I do a lot of shows with just the 01v96 without my system processor and have never felt the lack eq. Perhaps there are other things in how you are setting up the stage, the choice of microphones, and other details that are leading to the feedback problems.
Sent from my DROID RAZR HD using Tapatalk
Jay Barracato
Douglas R. Allen
Re: O1v96 advice
« Reply #4 on: March 26, 2015, 08:27:20 pm »
My 01v96 boots up and says 2003 so I've had mine for a few years.  If you need more eq for your mains you could assign your channels to a stereo bus. Go to group/pair layer. Select the output tab. Make bus 1+2 a stereo pair. To check this select your Master tab just right of layer 1-16 and 17 - 32 buttons.
Channels 9 and 10 or Bus 1 / 2 masters should be linked now. If you move up channel 9 , 10 should follow.
Now go to Pan-Route button and select you 1-16 route tab. These channels may be selected to S or stereo out. UNselect these channels from stereo and assign them to bus 1 and 2. Do the same for 17 - 32 if you use these channels as well.
Next select the Bus to St tab. Pan 1 to the Left. 2 to the right. Turn these channels on and bring the faders up to the top (unity) Please note if you run a mono PA you'll only need 1 Bus and need to run just the 1 master. Channel 1 panned to center.
Your ready to go back to your master layer now. Be sure to have channels 9-10 (bus masters) all the way up and turned on. Push channel 9 select button , Channel 10 should flash as well if linked correctly. With channel 9 selected push your eq high button. It should say eq Bus 1 - Bus 1. Because you have 9 and 10 stereo linked any eq changes on this channel will be reflected in 10 as well. If you eq on channel 9 , bus 1 master you'll see the same eq on channel 10 if you push its select button.
What all this does is run your channels through a bus on to the L/R master out. It gives you 4 more bands of parametric eq for your mains or 8 bands of parametric eq total. Quite a bit to need but thought I'd run this by you.
Please note this is from memory so the wording / overall tabs may not be 100 percent the same but I hope this will get you close enough.
Douglas R. Allen
« Last Edit: March 26, 2015, 08:39:28 pm by Douglas R. Allen »
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: O1v96 advice
« Reply #5 on: March 26, 2015, 08:42:39 pm »
lets start by finding out about the rest of your set up. What speakers, amps, mics are you using?
TimHackford
Re: O1v96 advice
« Reply #6 on: March 27, 2015, 04:58:26 am »
Douglas R. Allen
Wow I honestly couldnt of hoped or asked for a more detailed reply! Thank you ever so much Doug I will most certainly be giving this a go..still trying to understand all the routing options on this mixer and get a little lost at times its so different to the original o1v but you made that sound so easy to follow!
Tim  - I am using 2x SRM 450v2 speakers, 2x Alto Ts15" subwoofers, vocal microphones are Sennheiser E945's we use 3. Guitar cab mics are Shure 57 beta's, drums are mic'd with AKG drum set and SM57 on snare..bass we DI in as well as acoustics.
Thanks again guys you really are being more help then I could ever of hoped for.
Tim Weaver
Re: O1v96 advice
« Reply #7 on: March 27, 2015, 10:49:40 am »
I know you don't want to hear it, but I would look into upgrading your mackie's. You are using up a lot of EQ, simply because the mackie's don't sound that good out of the box and you have feedback or just sound quality issues to fix with the eq.
I'm sure I could make the 4 band parametric work (I also own an 01v96) but, I find that when I have to fight feedback AND make a crappy speaker sound good I start running out of EQ on the board pretty fast. One trick I do, that may work for you or not, is to double up the inputs on the second layer and use one set for the mains and the other set for monitors/iems. This allows you to have specific and wildly different eq curves on every input depending on where it will be used (mains vs monitors). You will have to remember which layer you are on when you make adjustments though. It can get tricky, and I wouldn't recommend it if you are running sound from the stage while playing!
Maybe look into the Yamaha DSR112's for a replacement to the mackie's. Those are excellent speakers. and will improve every facet of your performance.
TimHackford
Re: O1v96 advice
« Reply #8 on: April 14, 2016, 05:36:12 pm »
Hey Guys just thought I would give an update to my whole situtation I know its late and I'm sorry.
We got shot of the whole PA except the desk we now run
2X RCF 732a tops
2x RCF 905as Subs
and the sound is to our ears amazing!
I've got grips with the desk so much more now, there is no feedback anymore, it took a whole to figure out the gain structure with this desk tho Im still not sure I have it right here is how I'm running it now.
 I found that without the PAD switches engaged the sound was very on edge to feedback at all times tho this is how the manual tells you how to set the gain correctly by getting each or most channels to clipping occasionally then backing the gain down slightly..found this really not that great.
Where as with the PAD switches engaged its so much more manageble, We have a good sense of stage sound, and volume, all the amps are elevated and we have IEM's so no monitors to increase stage volume.
 I get the meters on the desk for the channels reading around -12 to -6 and if i need anymore gain on a channel that I cant get with the gain knob then I use the gain attentuator found on the channels EQ page seems to works really well!
I have the Master Fader at around -10 to -5 its around here I find is a really great sound, it pushes the speakers sightly to a really sweet spot and doesnt seem to damage them atall..the signal light is active but never gone to peak or anything. Due to them being active speakers I can control the volume of them to a non ear damaging level while still sounding excellent..we find generally we dont need to go past 10:30 or 11 O'Clock on the level control on the speakers.
Not too sure how many other guys are using the desk this way I know one guy that does and there band sounds phenominal..a really great sound..can hear every instruemnt perfectly very low noise floor and a very clear sound.
Do you guys think im doing anything wrong here or anything that is going to cause my speakers or desk any damage in the long run? We are gigging roughly 3 times a week so need this this be as reliable as possible!
Again sorry for the late reply just thought you may like an update!
Tim
Re: O1v96 advice
« Reply #9 on: April 17, 2016, 05:49:52 pm »
You are not going to get any more gain with the pads in vs the pads out.
The ONLY thing the pads will do is to lower a hot signal and keep the mic preamp from clipping.
It is another one of those audio myths.
People think that by putting in the pads they can turn up the level more.
Yes they can push the faders up higher, but the GAIN of the system will be the same because the signals will be LOWERED by the same amount.
Re: O1v96 advice
Page created in 0.076 seconds with 24 queries.
