Author Topic: What distribution box do I need for this?  (Read 5910 times)
Michael Lascuola
    • WoodlawnSound.com
« on: March 15, 2015, 12:35:52 pm »
I picked up an outdoor concert series, and here's the power that is provided.  It's clear that it's a PS-54-HR with a NEMA 14-50.  I looked at lots of sites, and I did not see exactly what I'm looking for.
Thanks!
Colorado Springs, CO
Michael Lascuola
    • WoodlawnSound.com
Re: What distribution box do I need for this?
« Reply #1 on: March 15, 2015, 12:54:33 pm »
I knew if I read through this section, I'd find something!  This, from another post looks like it will fill the bill:  http://peavey.com/products/index.cfm/item/964/117526/distro
Any other suggestions, please do!
Mark Cadwallader
  • Helena, Montana USA
« Reply #2 on: March 15, 2015, 01:08:03 pm »
For outdoor use, you might want to consider using a "spider box" with GFCIs. A spider box is a common construction item, and is probably available at a rental center near you, depending on whether it makes sense to buy one or not. IIRC, a new, made-in-USA spiderbox is about $500. CEP is a well known brand. Construction spider boxes are bright yellow (for visibility purposes) and typically have runners or a roll cage that hold them up off the ground (OSHA compliant and UL listed).  Mark C.
Michael Lascuola
    • WoodlawnSound.com
« Reply #3 on: March 15, 2015, 01:13:14 pm »
Thanks Mark!
All of the "spider boxes" I am seeing so far have the twist style plugs -- are the "range" style less common?
i.e.  http://www.northerntool.com/shop/tools/product_200434713_200434713
Mark Cadwallader
« Reply #4 on: March 15, 2015, 02:45:59 pm »
The standard solution is to build a short 14-50 to Calif connector pigtail. Because the spider box is rated for 50 amps, you could also build a 14-30 to Calif connector pigtail (but that would limit you to the 30 amp service.)  Mark C.
Edit:  To answer your question, a 14-50 is more common for RV service, but it is not as robust a connection if you are attaching an extension cable.
« Last Edit: March 15, 2015, 02:51:24 pm by Mark Cadwallader »
Rob Spence
  • Boston Metro North/West
    • Lynx Audio Services
« Reply #5 on: March 15, 2015, 11:08:00 pm »
I ran into one if those at a fairground. I tried a standard range plug and damn if the right angle put the cord up the top. Fortunately for me, I had built the cable so I took it apart and rotated the pin end 180.
So, buy some 6-4 SOOW and put a California female on one end and a straight 14-50 on the other.
TJ (Tom) Cornish
  • St. Paul, MN
« Reply #6 on: March 16, 2015, 07:05:38 am »
The receptacle in the picture is oriented correctly - the ground pin goes on top. It's definitely possible to run into receptacles oriented incorrectly, but I haven't seen too many.
The correct cord for a California or 14-50 is 4/4 SOOW, not 6/4 SOOW unless you're sure you will never plug into a receptacle fed from a 3-phase service and will not run non-linear line to neutral loads. As that's a pretty tall order in our world, the neutral conductor counts as current-carrying, which derates the 6/4 cable to 45 amps.
Jeff Baumgartner
« Reply #7 on: March 16, 2015, 08:36:52 am »
Jim at the Amp Shop makes breakouts for this very plug.
http://www.ampshop.com/distro.html
Terry Martin
« Reply #8 on: March 16, 2015, 08:57:02 am »
I have a couple of Jims distro's.  He does good work.  But they won't (at least mine don't) have the certifications that may be a requirement in your jurisdiction.
« Reply #9 on: March 16, 2015, 11:10:50 am »
Jim is recovering from a circuit breaker shortage, he just got another shipment in and is working overtime to clear his backlog.  He's a great guy to work with.
Terry correctly points out that AmpShop products do not carry a Listing agency sticker.  AmpShop can have distros CSA approved, but it's done on a piece basis and requires that the assemblies are shipped to Canada to be inspected, stickered and returned to the USA.  This adds about 35% to the price and needs to be pre-arranged through Jim.
If one must have UL stickers on the devices and assemblies one will probably spend close to 2x of AmpShop's prices at Lex, TMB/ProPower, Motion Labs, Whirlwind etc.
Page created in 0.07 seconds with 23 queries.
