Author Topic: FS: HHB CDR830 BurnIT Plus  (Read 1300 times)
robberns
« on: February 23, 2015, 11:19:59 am »
Rack-mount CD-R/RW with Digital and Analog inputs and outputs.
I only used it as a player, not a burner, so I can't vouch for how it burns CD's.
I did use the AES/EBU Digital Output, which works great. Analog outs also work fine.
[COLOR="Red"]$150.00 shipped in the CONUS.[/COLOR]
The CDR830 BurnIT Plus is a stand-alone professional CD burner featuring high precision 24-bit analog to digital and 24-bit multi-level Delta Sigma digital to analog converters. The unit's specifications are exactly the same as for the CDR830 BurnIT except for the addition of XLR balanced analog inputs and outputs, AES/EBU input and output and the addition of a WC BNC input. The design of the laser assembly means that every single CD-R and CD-RW disc written is very accurate, providing greater compatibility with other CD players and recorders. Solidly built for studio use, the unit records on readily available, low cost discs and features a SCMS-free digital input.
Aside from recording from an analog source, recording from CD, DAT, MD or hard disk is easy using the unit's digital input. A built-in Sample Rate Converter (SRC) accepts sampling rates from 32kHz to 48kHz. Three synchro-recording modes allow burning a single track, all tracks and all tracks with finalizing. When recording from a digital source, the CDR830 BurnIT Plus's digital record gain control can adjust the signal input level, enabling gain adjustment for individual tracks. This is perfect when recording a compilation CD from many different sources, since some tracks may be at a higher or lower volume level. All digital inputs have their own level control.
All signal levels can be monitored during recording or playback using the LCD meters, with an input monitor facility also provided. The CDR830 BurnIT Plus also has a left/right digital balance control, enabling the balance of digital and analog sources to be adjusted before they are recorded. A CD Text feature enables the user to store disc, track and artist names on the disc. This information is then displayed whenever the disc is played on a CD Text compatible CD player or recorder. Each entry can be up to 120 characters in length (including spaces), with title scrolling if it is too long to fit in the display.
FEATURES
High-precision 24-bit A-D converters and 24-bit multilevel Delta Sigma D/A converters ensure exceptional sound quality
Advanced laser assembly delivers consistently accurate recordings, compatible with a wide range of CD players
CD Text display input and editing enables disc, artist, and track names to be stored
Records on both standard and consumer audio CDR and CDRW discs
Straightforward digital and analog synchro recording with 1 Track, All Tracks, and All Tracks with Finalize synchro modes
Digital input gain control enables balancing of recordings made from different digital sources, e.g. CD, DAT, MD, etc.
Digital left-right balance control
Double speed CD finalization
SPECIFICATIONS
CDR830PLUS Burnit Plus Pro CD Recorder
   ▪   Format: Compact Disc Recordable
   ▪   Compatible discs: CD (playback), CDR and CDRW
   ▪   Channels: 2 (stereo)
   ▪   Power supply: AC 120V, 60Hz
   ▪   Power consumption: 14W
   ▪   Operating temperature: +41 degrees F to +95 degrees F
   ▪   Weight: 8 lbs.
   ▪   Maximum dimensions: 19"W x 4-1/10"H x 11-3/5"D (3-1/2"H without feet)
   ▪   Remote control: Parallel connector (mini-DIN) or Infrared
   ▪   Frequency response: 10Hz to 20kHz 0.5dB
   ▪   RCA phono output level (0dBFS, >10k load): 9dBu
   ▪   Wow & flutter: Unmeasurable
   ▪   Playback
   ▪   Signal to noise ratio: >111dB
   ▪   Dynamic range: >98dB
   ▪   Total harmonic distortion @ 1kHz: <0.002%
   ▪   Channel separation: >98dB
   ▪   Recording (analog input)
   ▪   Signal to noise ratio: >92dB
   ▪   Dynamic range: >92dB
   ▪   Total harmonic distortion @ 1kHz: <0.003%
   ▪   Recording (digital S/PDIF input)
   ▪   Signal to noise ratio: >108dB
   ▪   Dynamic range: >97dB
   ▪   All audio measurements are to EIAJ standards.
   ▪   Analog connectors:
   ▪   Unbalanced line input: RCA phono (input impedance 10kΩ)
   ▪   Unbalanced line output: RCA phono
   ▪   Balanced line input: XLR (F)
   ▪   Balanced line output: XLR (M)
   ▪   Headphone output: 1/4" stereo jack
   ▪   Digital connectors:
   ▪   Optical digital input (S/PDIF): TOSlink, optical wavelength 660nm 30nm
   ▪   Optical digital output (S/PDIF): TOSlink, optical wavelength 660nm 30nm
   ▪   Coaxial digital input (S/PDIF): RCA phono, 75Ω, IEC958 type II
   ▪   Coaxial digital output (S/PDIF): RCA phono, 75Ω, IEC958 type II
   ▪   Balanced digital input: XLR 110Ω
   ▪   Balanced digital output: XLR 110Ω
   ▪   Word clock input (operating range 32kHz to 48kHz): BNC
Page created in 0.039 seconds with 22 queries.
