Author Topic: qsc pld4.5  (Read 9474 times)
shelby hoyl
qsc pld4.5
« on: February 16, 2015, 05:44:48 am »
I just got the qsc pld4.5 this week, and have had only one gig with it . but my experience with it has been a good one so far. the first 2 ch i used to run a pair of sound bridge s3. the amp put out a nice clean crisp sound for the highs. the other 2 ch i used on a pair of jbl sr4719x. usually i run the subs with a Mackie 2500 amp bridge @ 4 ohm to each sub, and they hit hard. so i was a little disappointed when i was at the gig. the qsc pld4.5 did not hit as hard as the Mackie's amps would have. but that being said the subs still but out more bass than those kids where used to. i'm still in the experimental phase with this amp and will try different configurations with this amp at home and at other gigs, and i will get back to y'all. fill free to ask me any questions.
Ben Heavenrich
Re: qsc pld4.5
« Reply #1 on: March 02, 2015, 02:29:29 pm »
I don't think that amp would be efficient for powering subwoofers, as you would have to bridge at least two channels to get real power out of it. Which takes away from the point of a 4 channel amplifier. I think you're better off using that amp to power 2 tops  biamped, or two tops and monitors, etc. For the subs I'd look into the QSC PL380, that is really the only amp QSC makes that will do those subs justice. More power the better for subs!
shelby hoyl
Re: qsc pld4.5
« Reply #2 on: March 03, 2015, 12:59:52 pm »
The reason i bought it was for the versatility of the amp. The point of this amp is to have whatever i need on whatever gig i have. i did look into the qsc pl380, the price of that amp is higher there is no d.s.p and it looks to me like the power output is about the same as the 4.5
« Last Edit: March 03, 2015, 02:51:48 pm by shelby hoyl »
shelby hoyl
Re: qsc pld4.5
« Reply #3 on: March 03, 2015, 03:01:41 pm »
this is my 3rd gig with this amp. so far so good.
g'bye, Dick Rees
  • Duluth
Re: qsc pld4.5
« Reply #4 on: March 03, 2015, 03:11:14 pm »
Please don't tell me you've got your power amp plugged into a "power conditioner"...
shelby hoyl
Re: qsc pld4.5
« Reply #5 on: March 03, 2015, 08:44:05 pm »
yes, why do you ask?
g'bye, Dick Rees
  • Duluth
Re: qsc pld4.5
« Reply #6 on: March 03, 2015, 09:24:22 pm »
1.  You don't need it and
2.   It can cause problems.
For example, if your power strip is rated for 15 amps and your amp can draw 20 for full output, you'll either starve the amp or trip the breaker/blow a fuse.
Standard practice is to avoid such units for your amps.  They are of questionable benefit in any case.
Tim Weaver
  • College Station, Texas
    • Daniela Weaver Photography
Re: qsc pld4.5
« Reply #7 on: March 04, 2015, 01:43:33 am »
There's two things that power conditioners are good for: Convenient  outlets, and pull-out lights.
I wish they would just do those two things and spare me the expense of "conditioning" my power....
George Dougherty
Re: qsc pld4.5
« Reply #8 on: March 05, 2015, 11:59:25 am »
Those are called rack mount power distribution units  or PDU. They usually are breakered but without any of the filtering.
Doug Fowler
  • Saint Louis, MO USA
Re: qsc pld4.5
« Reply #9 on: March 05, 2015, 12:50:32 pm »
Thank you. These devices are not "power conditioners".
Re: qsc pld4.5
Page created in 1.124 seconds with 25 queries.
